Denisesewa
Well, I finaly have a battery issue in build #1 , I am using 2ea 5 cell and 1ea 4 cell Turnigy 5000 mah 25c batteries is series and two of these packs parallal for 14s 2p 10ah. I have been balance charging these individually every 5 cycles and they have all been very close in cell voltage at the start of charging. this time however one of the parallal packs had all three individual packs puffed while the other pack is still fine ? Seems odd to me. I have never run this system below 30% capacity and have been well below 50% of the rated "C" discharge. On bike #2 I am using two seperate 14s packs which I like better since I can run the first to LVC and then switch to the second for the return trip with the bonus of having full voltage again halfway thru the ride.
So, it seems there may be an issue with simply plugging these turnigy packs together in series and then using a parallel harness to obtain 14s 2p but I cant get my head around why this might be? Also the puffed packs individual cells read the same voltage as the non puffed pack cells before charging, I did not try to charge the puffed packs.
I suppose its time I built a balance harness to balance charge these as one pack together and I am going to split the pack as I did in the second bike, I need to anyway unless I purchase all the packs needed to build an entire new battery.
Thoughts on this anyone ?
