BiGH said:and that is why i'm going to most likely source a 5303 motor on a 26" rim as opposed to a 5304 motor on a 24" rim![]()
eP said:Hi BiGH
Keep in mind Lowell reach the controller's limit at that speed. So you cannot much load the same controller.
When you use the same rim you need the same torque, but for 5303 you need 1/3 more current for the same torque than you need at 5304.
So you get the same voltage sag at motor side as the 5304 has 1/3 more turns than 5303. But at higher current you get higher loss, so if you are at the contr. limit 5303 cannot put out even the same power as 5304 can.
5303 could be the same or better efficient at 20'' or less rim if you compare to 5304 at 26'' rim.
5303 could draw more power from controller if the low source voltage is the power limit. When the max current is reached at WOT you cannot get more power from the controller.
Regards.
BiGH said:awesomelooking forward to your future mods.
i was just basing it off the 60amps on what was written in one of the threads on your bike - which i have to say i've read a few timeslove that bike...
Lowell said:Glad you like the bike, I hope the info I've posted helps people out with their own creations.
Lowell said:Interesting how you seem to know more about my speed controller than I do. For the record, the current limit is set just over 80 amps. 81-82 amps to be exact. The limiting factor on my bike is batteries. They're only rated for 3C drain which is 56-60amps. That will be changing soon though as I will be upgrading to 90V+ at 80 amps down low, and hopefully around 50-55A at speed. Should the stator burn up during testing, I'll be upgrading the controller to 150V and replacing the 03 with an '04 wind.
BiGH said:but wouldn't it mean that even tho it was more efficieint, it would be at a lower speed?
ie:
for a given voltage / amperage a 5304 motor will give a lower speed, but a better efficiency
for the same voltage/amperage a 5303 motor will give a higher speed, but lower efficiency.
