Lowell said:
Better efficiency certainly doesn't hurt, but how far do you guys actually ride in one trip? I built my bike with my 21 mile commute to work in mind, which tt comfortably covers in 37 minutes while using 2/3 of the battery charge. Hub motors are no good on hills? 35mph up a 13% grade proves that wrong. Does anyone have a geared ebike that is faster up a similar grade?
Hi
Lowell
If you climb at 35mph up a 13% grade, so what is your speed at opposite direction ?
At hilly area i can trip up to 30 miles, at flat much more - at really cheap old bike without any assistance.
So with assistance at critical paths ( high grade hills ) my range could grow up to 50 miles i hope (at small wh amount if i used regen at downhill).
Average 10 mph is good enough for me - i like to see all around when i cycling, especially at top of the hills. At higher speed i have to pay much attention to ground(road) to avoid bad surprice's.
I like cycling at sunny days(i'm not alone i'm sure) so it could be possible using small solar panels (40-60W) at stops at longer trips at such low average trip speed and high efficiency.
Big heavy cells and grid charger it is not good idea when you hilly cycling without acces to grid.
And for me (and many others) big battery price is still prohibitive.
