It is not possible to do the arm or drv chips with the oven, you need to do it with a solder iron. I made a video using a tiny flat tip iron I bought, works perfectly. It is tricky to do it with any soldering iron but it is possible. Make sure the pins are lined up exactly with the pads, otherwise they will bridge with solder. Then with enough flux you will get the hang of it, the solder goes where it should and does not bridge like in this video.
[youtube]c6E_rA1rGto[/youtube]
