fechter said:
Find a bazooka and shoot the thing. It won't run any better but you'll feel less frustrated.
I sold my bazooka to some black guys that live in Ferguson, MO. I don't know why they wanted it so bad
I would have abandoned the project already if it were my car. There's a point at which it's more efficient monetarily (considering labor as well) to buy a replacement used car, which would be in better condition. However, my housemate, an 84 year old who owns the house, owns the car. I had previously done all the repairs on his car (his previous car), and nothing really presented an insurmountable challenge. This time though, during a senile moment, you could say, he traded his previous car for this one.
I was rather upset because I had
changed almost everything on his previous car. And this car, although newer in years, was more than a 100,000 miles older and he paid 1k$ usd to boot.
In this repair, my housemate is paying for the parts and I'm doing the labor free. He doesn't have a large amount of money for parts though.
fechter said:
The EGR module contained most of the likely suspects. I thought you measured the manifold vacuum at idle and it was more or less normal. Any kind of leak will drop the vacuum. It still sounds like it's running lean.
I've heard of people using propane to find a leak. Turn on your torch without lighting it and blow propane around areas suspected of leaking while the engine is idling. If you find a leak, the engine RPM will increase.
There's a remote chance there is a bad wiring connection between one of the sensors and the ECU, but that almost always throws a code. Very remote chance the ECU is bad.
I had forgotten about the propane method of finding vacuum leaks. I've been using diethyl ether (starting fluid). I've read about pressurizing the intake manifold and then checking with soapy water too.
Last time I checked, I was getting 16 inched Hg vacuum when specs say 15-22. That could mean it's a bit low. I now have a new gauge, so I'll check again plus I'll try the propane test.
marty said:
Engine needs air - Hows does the air filter look?
Engine needs sparks - Remove and inspect all spark plugs.
Engine needs gas - Measure fuel pump pressure.
...Did you get the service manual fired up?
I replaced the fuel filter and fuel pump, and although I didn't do a pressure check on the new one, I did look at the flow and it looked fine.
I also replaced the plugs. That, actually, was the original request of the car's owner.
I also changed the air filter and cleaned the MAF sensor.
I'm still working on getting the manual open. I think I'll be able to do it.
I'm now suspecting the CHT (Cylinder Head Temperature) sensor, which is hard to get to but I can access the wires to it. I also suspect the fuel rail pressure temperature sensor. And I'm beginning to wonder about throttle position sensor.
Also, I suppose I should report, in addition to being not-startable when warm, the engine is hard to start when cold. I can rev it up in idle. (You can ignore the clicking sound; it's just a meaningless plastic thing.) https://plus.google.com/u/0/photos/113157811476977440257/albums/6082509083790270657/6082509087219277506?pid=6082509087219277506&oid=113157811476977440257 not really a very interesting clip.
Yes, I've also thought of a problem with the PCM (Powertrain Control Module). It's hard for be to believe that went bad, but a guy in another group states his went.
