xyster
Discussion branched from Andrey's question here:
http://endless-sphere.com/forums/viewtopic.php?p=4416#4416
Compared to maintaining a single, intended speed, is it more or less efficient to "pulse" the throttle to get to a faster speed then one intends to ride, then coast down below that intended speed, and then pulse again ad infinitum?
http://www.metrompg.com/posts/mpg-miscellany.htm#pulse
Is this correct? Seems to me the extra power demanded during acceleration is not completely countered by the power saved during the coasting phase. Perhaps it works for ICE engines with a narrow powerband, but if so, why don't racers and cost-conscious drivers use the technique more?
There's also the Peukert effect to consider with EV's. This is discussed somewhat here, from where the above quote originated:
http://autos.groups.yahoo.com/group/ev-list-archive/messages/57787?threaded=1&m=e&var=1&tidx=1
"> Does pulse and glide help EV's?
Yes, it can if done properly. But you have to understand why it works to do it properly.
ICEs have a strong efficiency peak at some particular horsepower, which is usually some substantial fraction of full horsepower. For example, a 100hp engine might be most efficient at 50hp. But if you run it at 10hp or 100hp, it is less than half as efficient (uses twice as much fuel per horsepower).
The trouble is, the vehicle itself is most efficient at low speeds, where wind resistance is negligible. So the slower you go, the more efficient the vehicle gets but the less efficient the ICE is.
If you drive at a constant speed, then the best fuel economy occurs where the product of the vehicle and engine efficiencies reach a peak. This typically occurs at 30-40 mph. But the vehicle only needs 5-10hp to drive at this speed, so its efficiency is less than half its peak
efficiency.
Fuel economy champs found a strategy to beat this problem long ago. The trick is to always run the engine at its peak efficiency (say 50hp), or shut it off entirely. But keep the vehicle speed as low as possible, so aerodynamic losses are negligible. Start at some very low speed like 10 mph. Put it in gear so the car's momentum starts the engine. Run the engine at 50hp, which makes the car accellerate strongly. When you reach the speed where wind resistance losses begin (like 40 mph), shut off the engine, take it out of gear, and coast back down to 10 mph. This is "pulse & glide". On any car, you can at least *double* your fuel economy by driving this way.
The same principle applies to an EV, except that the electric motor has a much flatter efficiency vs. horsepower curve. A motor might peak at 85% efficiency at 20hp, but is still 75% efficient from 1hp to 50hp. This means there is less to be gained by pulse & glide. So pulse & glide would give you an extra 10% range, not double the range."
