I got all the parts to build the 3 boards I have. The ones I have are Arduino nano powered and writing code for Arduino is easy. I will post it when I find it.fechter said:Most of the board is pretty straightforward to design. The part I would have trouble with is the code for the PIC. I'm not so good at that. Seems like it's fairly simple from a programming standpoint for someone with experience. I have an analog version of a timing circuit that would produce the same kind of output using 3 timer chips but the parts count is a lot higher. The PIC or something similar makes things much cleaner.
One idea I had is if Riba would share his source code for the PIC, someone 'trusted' could make and sell programmed chips and give a percentage to Riba as a license fee. It's not going to make anyone rich but it would make these available again. The rest of the board is easy and an improved design could be made.
I've been very happy with the results I got with the original design Riba made, though I added a flyback diode.
spinningmagnets said:I readily admit that I'm a doofus when it comes to electronics. That being said, I have a couple of questions.
It "sounds like" some of the FETs were damaged from excessive heat, and the cure was waiting between spot-welds longer to allow them to cool. Couldn't this design simply double the number of FETs?
Lebowski arranges his DIY controller FETs in groups, instead of in a long line. Would doing that here for the spot welder reduce inductance? I'm imagining two aluminum bars/plates with three threaded holes each. Each hole can have a FET screwed on from each side. Three FETs on one side, three on the other. Two heat sink bars = 12 FETs. Or...any layout that dramatically reduces inductance simply by a clever physical layout.
Maybe a two sided board? Four FETs on one side, four mirrored on the other (slightly offset so pins aren't conflicting). The Adaptto controller uses larger "package" FETs. Fewer FETs, but higher current per FET = compact layout = low inductance?
If the "turn off" causes cascading voltage spikes (27V was mentioned, from a 12V system), could we use common 60V FETs from an old ebike controller?
Arlo1 said:I got all the parts to build the 3 boards I have. The ones I have are Arduino nano powered and writing code for Arduino is easy. I will post it when I find it.
Also I will test the boards and see what I can do to make them switch clean and safe. Mine use 60v rated fets which is most likely for the big overshoot at turn off.
I can redesign these if people want and use something with a better driver. But when you shut off to fast it will cause a very big voltage spike which is likely whats killing most boards on this forum.
$3 ushttp://www.banggood.com/ATmega328P-Nano-V3-Controller-Board-Compatible-Arduino-p-940937.htmlfechter said:Arlo1 said:I got all the parts to build the 3 boards I have. The ones I have are Arduino nano powered and writing code for Arduino is easy. I will post it when I find it.
How much do Audrio nano boards cost?
fechter said:Yes, I was referring to the gate driver about switching speed. There seems to be a wide variety of opinions on what is best.
fechter said:Banggood? Like it goes bang. Got to love those Chinese names. Like all the lithium batteries with 'fire' in the name.
Anyway, that's plenty cheap. I like it.
riba2233 said:Two rightmost fets have longer current path... May not be fatal, but not good.
If you are, of course, willing to take my humble advice. I know I'm not your welder guru, but still :lol:
Also, long wires for gate signals - random soldering... Not looking too good. Also those resistors could act like antennas...
Arlo1 said:riba2233 said:Two rightmost fets have longer current path... May not be fatal, but not good.
This is gold right here. Listen to Riba.
destro23 said:I Origionally posted this in an AUS-Spot welder Thread and realized i'm making a North American list of parts that we can get from Mouser. So i'm reposting this list here and will ask to have the other deleted.
Below is the closest mouser parts I can find.... The only issue I have is possible differences and how it'll effect the final welder.
We can use this a starting point for a North American parts list.
Everything underlined is the closest i can find on mouser...If i can get a full list that everyone can agree on maybe i can ask to update the file on github for us on this side of the pond.
Mosfet IRF1405 55V 169A IRF 1405 1.15 € 9.20 € Infineon / IR IRF1405PBF
Mosfet Driver MCP14E10-E/P MCP 14E10-E/P 1.70 € 6.80 € Microchip Technology MCP14E10-E/P
Poti 6mm Linear 50K RK09K113-LIN50K 0.99 €
7 Segment Display SC 56-11 RT 0.84 € Kingbright SC56-21EWA
1x20pol female header BL 1X20G8 2,54 0.26 € Harwin M20-7822046
1x36pol male header SL 1X36G 2,54 0.17 € 3M Electronic Solutions Division 929647-01-36-I
PCB connector set 2pin PS 25/2G WS 0.29 €
IC socket 8 pole GS 8 0.03 € 0.12 €
diode 1N5817 1N 5817 0.06 € 863-1N5817RLG
elektrolytic capacitor 1 µF RAD 1/63 0.04 € 598-SK010M063ST
ceramic capacitor 100pF KERKO 100P 0.06 €
Resistor 221 Ohm METALL 221 0.08 € 0.16 € 603-MFR-25FBF52-221R
Resistor 100K-Ohm METALL 100K 0.08 € 279-LR1F100K
LED 5mm green LED 5MM GN 0.06 € 696-SSL-LX5093GDTR
Just realized again i'm in wrong thread again.. this is the for adruino spot welder in instructibles.
Quokka said:I think you may have the wrong poti. Pretty sure you need a 10k version
Poti 6mm Linear 50K RK09K113-LIN50K 0.99 € ALPS RK09D1130A1L
ceramic capacitor 100pF KERKO 100P 0.06 € Xicon 140-50P2-101K-RC
Jorge Rocha said:Hello everyone,
I have bought a spot welder to Ribas, and everything worked well, 'till now, since the last week i'm having problems with the mosfets, i blow 2 of them 1 week ago and i replace them, now yesterday i just blow more 3, i don't understand why is that happening 'cause i'm doing everything normal (i'm welding 18650 samsung cells), does anyone know what's possible going on to blow the mosfets?
