okashira
We already have the avalanche taken care of... Ive documented it pretty well
A $3 diode and $2.5 TVS diode takes care of it
atomek1000 said:Hey guys i've got a quick question. Did anybody had an issue with blown resistors going to mosfet gate leg? I have the 1-gen riba spotwelder with 6x AUIRF1324 and they seem to be ok but i heard a big puff and found out that 2 of this 820 resistors are blown up.
What are these resistors for? Should i just replace them and go on or do you recommend modyfing/checking something before welding again? I heard about diode mod but i have regular car battery about 700A and haven't had any problems for 1 year so i don't think this was issue of fly back current or was it?![]()
Arlo1 said:Not a bad first post.
okashira said:We already have the avalanche taken care of... Ive documented it pretty well
Tesseract said:atomek1000 said:Hey guys i've got a quick question. Did anybody had an issue with blown resistors going to mosfet gate leg? I have the 1-gen riba spotwelder with 6x AUIRF1324 and they seem to be ok but i heard a big puff and found out that 2 of this 820 resistors are blown up.
Gate resistors don't fail unless the MOSFET has failed, so if one or more of the resistors popped then so did their respective MOSFET(s).
And yes, it is entirely possible for the MOSFETs to survive a number of avalanche cycles before failing. The relevant graph from the AUIRF1234 datasheet is attached with highlighting in red of the applicable values. Note that the recommended peak drain current is 195A per MOSFET so 6 in parallel would only be good for about 1200A peak which I would think is insufficient for this application unless the lead-acid battery is tired and/or fairly small (say, under 40Ah of capacity). [EDIT] - also note that the repetitive avalanche energy is 175mJ per pulse so 1.05J total assuming equal division of avalanche energy (which is a poor/likely fatal assumption). If you plug this energy rating into the equation I=(E/(0.5*L))^0.5 you get an allowed peak current of 1024A to stay under the total avalanche rating (though, again, one should not assume that paralleled MOSFETs will share avalanche energy evenly - in fact, they are all but guaranteed not to!)
Also, 820 ohms is way too high for a gate resistor and while higher gate resistor values do slow down the rate of rise in drain voltage during turn-off, that doesn't actually reduce the energy during avalanche as the latter is strictly a function of peak current and cable inductance (0.5LI²).
Tesseract said:...you don't want to avalanche FETs unless your goal is to create extremely fast transitions and/or lots of ringing - the appropriate solution is to use a freewheeling (or flyback) diode from the FET drain(s) to the positive rail (which needs to be decoupled with a decent amount of capacitance).
atomek1000 said:Thanks for very informative answer, the mosfets in this configuration handled about 35 000 weld pulses but recently i started to weld while charging lead-acid battery and voltage was little higher than always, maybe that's what lead to failure.
Gate resistors are 82 ohms (820 marking on them).
pguk said:okashira said:Tesseract said:...you don't want to avalanche FETs unless your goal is to create extremely fast transitions and/or lots of ringing - the appropriate solution is to use a freewheeling (or flyback) diode from the FET drain(s) to the positive rail (which needs to be decoupled with a decent amount of capacitance).
So this is a new idea. If I were to add a decoupling capacitor for the freewheeling diode, do you mean I should connect it in parrallel with the schottky? Or else from drains to GND?
pguk said:okashira said:We already have the avalanche taken care of... Ive documented it pretty well
I updated my post on previous page with a scope shot of TVS diode added along with my homebrew freewheeler.
Which Schottky have you used at $3?
fechter said:okashira said:I think that would help a little bit. But with flyback diode and TVS diode, the problem seems to be completely solved anyway.
Diode I am using now is like $3 and TVS is like $2.50.
I agree, but I'd be curious to see how it looks on your scope anyway. If just bundling the wires together solves the problem, that might be easier (though I would still use the diodes).
okashira said:I wouldn't bother with a cap. It would need to be rather massive (expensiveness) to absorbe the inductive energy at turn off.
okashira said:You have no idea what you are talking about. Read the thread and stop coming in here shooting from the hip confusing people. This is not a half bridge topology you can't just slap on a small dc link cap and call it a day.
Yup, okashira is right, you need to go back and see what is discussed here. The circuit is actually clamped on the battery terminal, and free wheeling occurs on opposite to battery side I would say.Arlo1 said:the battery is to far away
parabellum said:Yup, okashira is right, you need to go back and see what is discussed here. The circuit is actually clamped on the battery terminal, and free wheeling occurs on opposite to battery side I would say.Arlo1 said:the battery is to far away
spinningmagnets said:...
What improvements help?
How much do they help, and in what way?
What is the point of diminishing returns? (that point where it "could" be better, but any further improvements beyond "X" are expensive for a small bump)
You guys all know more than me about this stuff. I think we can get these into production very fast, and at a low price. Maybe a basic model, and the upscale deluxe model, If we can only get some kind of consensus. Help me...to help you.
flangefrog said:Why is it that brushless controllers (at least the little ones like Kunteng) use a film cap on the mosfet drain for protection instead of a flyback schottky diode (and/or a TVS diode)?
Arlo said:The boards I have work on the negative side. By the end of this I will have designed new boards which will have added diodes and caps to make it work buttery smooth.
Tesseract said:I would use a stronger gate driver IC - I'd like to see at least 4A peak here - and lower the value of the gate resistors accordingly. For example, MIC4420, a 6A driver for $0.95US, and 22 ohm resistors for each MOSFET (whether 6 or 8 are used).
Tesseract said:parabellum said:Yup, okashira is right, you need to go back and see what is discussed here. The circuit is actually clamped on the battery terminal, and free wheeling occurs on opposite to battery side I would say.Arlo1 said:the battery is to far away
No, okashira is wrong, and there are *two* inductances that need to be dealt with. Energy stored in the inductance of the welding cables circulates through the freewheeling diode (if present), but what about the inductance of the battery cable (assuming the other connection to the battery is made directly by bolting the board to the battery terminal)? A capacitor across the input rails on the MOSFET board will absorb energy stored in the battery cable inductance when the MOSFETs turn off, with a brief bump in voltage that is inversely proportional to the amount of capacitance (and directly proportional to the battery cable inductance and peak current).
The amount of capacitance need not be obscene, either, but it does need to consist of some very low inductance/ESR ceramic or film capacitors in parallel with some electrolytics. A total capacitance around 4700uF should be sufficient to limit voltage overshoot to 20V with ~30cm of battery cable and 2000A of peak current. Personally, I'd go with a few uF of film capacitance (Sprague "orange drop" or the like) and 4-6 1000uF/16V elkos. [EDIT] Yes, 16V elkos are fine as the voltage will only exceed 16V very briefly and elkos will tolerate this abuse just fine.
However, there is not nearly as much energy stored in the battery side inductance - assuming there is one cable and it is as short as possible - so a TVS diode (at least 15KPA or SMDJ size) or just letting the energy avalanche the MOSFETs (and freewheeling diode, if present) is probably acceptable. It offends my sense of good engineering, but, then again, so does blindly dumping current from a battery into a spot weld, and that seems to work pretty well for most people here.
Dunno - I'm neither familiar with "little brushless controllers" nor do I have any special insight into what any particular designer might have been thinking when they designed something. It could be you are mistaken on the location of the capacitor, or it could be a means to achieve zero voltage switching, or it could be bad engineering.
