Well, that lasted about 7 miles!!
The carpet tape I got must be the wrong type, it's "indoor/outdoor" but soon as the drive has been used it starts letting go.
I got some new 80 grit belt and a 3M "Industrial Mounting Tape" that is rated for outdoor use on any surface, good for -20 and + 200 F.
What a difference! No problems with the tape at all, but I'm averaging about 800W of power, peak 1300W, all this with three Turnigy Nano LiPo 25 - 50c 4s, 6000 mah in parallel, so 18AH of 15V, and that good for me at 175, tools 30lbs, (I always go with everything I need for just about any road-side repair) bike 41 lbs (that's 16lbs of K-drive, batteries Batman accessories, Wattmeter, Speeds, etc ....) so a total of 246 lbs, and I'm cruising at 23 MPH on the flat, 21 MPH with a headwind, and it's WOW fast acceleration!
Not quite as snappy of acceleration as when I was running 8S (30V) on my last motor 295KV vs now 200KV and loads of copper, but hey, no magic smoke, or even HEAT yet!
I haven't totally flogged it yet, but I went up the hill that killed my first motor (running 8S, 295KV E-Flight 110) that averages about 6% at 15MPH and NOTHING even gets warm! Granted I am riding in 40 F weather with a light sprinkling of water most of the time, so that keeps things cooler, but so far, the ONLY thing that has heated up in the least are the batteries, and they only get slightly warm to the touch, so slight that you're not even sure it's warm, and that was when I took a 12% at 9MPH being cautious!
I have been running an average of 20 AMPs most of the time, it spikes to 30-50A depending on the hill, on a really steep hill (12%) I might hit 80A at the start (this still with me pedaling first to at least 7 MPH) and then settle down to 30-50 on a steep hill, and most of the time on stuff below 3%, I only pull 10 - 20A!!
I am extremely pleased with the build so far, and once I get a good tire/friction strip combo that I like, it will be perfect! 8)
