Pajda said:The principle of this issue was already formally described in this topic. So yes HP cells have significantly worse cycle life than most HE cells under low loads up to ca 1-2C continuous discharge. Generally(Although I do not like generalizations) HP cells cycle life is almost independent of the load. That means that HP cells should be used only in applications which really needs HP cells. From my point of view there are three fundamental categories of the cells on the market if we take a cycle life into account.
HE cells (up to 1C continuous) M36, MJ1, GA, 35E
"BP" (balanced parameters) cells (up to 3C continuous) 29E, M29
HP cells (more than 3C continuous) 30Q, HG2, VTC6
I want to quote this since it so meaningful.
Many thanks Pajda :thumb:
