John Bozi:
can understand your mood. To replace the old jackshaft with a new one is not a "quick repair"
Especialy when old axle bend, its hard to get her out of the housing, even with haevy tools.
Had to do that 3 times on firends bike, needed a lot of patience and some reggae music... not a srewdrifer-task. More a job for a sledgehammer, depends on how much the old axle bent.
Hope that the DT Swiss will also solve your problems, there would be even stronger "high torque"-ones but cost much more money.
You do pionier-work on that, + your hills look cracy steep.
Did you upgrade to the new 15mm jackshaft? / is this now available?.. for the smallblock, the new 12mm stainless works very well, no problems since.
Mike:
As a last upgrade for the smallblock-kit on our bikes, we would like the small sheet, that holds the Jackshaft-Setscrews, made from unbendable stainless steel.
Spinning Magnets:
im not sure how much more power i can give on the Bike-Chain, but im willing to try whats possible
. Since i changed my reduction and did all the stuff i wrote in my "Review", everything runs smooth. Same Chain on since.
I think maybe the bike chain holds up because i changed the overdrife (on Bike-chain) in a 1:1-like reduction. Not sure if that makes sense, just a feeling.
Since then i havent problems with the Bikechain, Dereilleur or sprokets. (only use the biggest 3 Sprokets 90% of the time)
now, that all the Bikes run so problem free, i started to get sloppy and didnt screw the pedal on the crankarm propper...
it came loose, i screewed it on only by hand an then ride another 10 km without checking on it (totally forgot about it while riding)... that was dumb.
Threads on the Alu-Crankarm are no more. Just a hole there now.
Have an other ISIS-Crankarm here to replace, will do that tomorrow and maybe writing about it in the "Review".
Its also not a easy thing to do, since i needed to make a spezial tool to remove the WI FW. My normal FW-removal tool (good for ACS) didnt work on the WI (little to small, slipped when apllying force on it)
noobquestion:
how much amps can i get out of a Infineon 12 fet (hall sensors) thats rated 40 amps max?
have CA now set to 46 Amp and 3800 Watt @ 75Volt-Pack (near 90V fresh from the charger), but cant see much over 3200 Watt on the display. Wondering if controller dont allow more, or what else may be the limiting factor.?
Cheers guys
