LightningRods
Deanwvu said:What brand/model of chain would be best for this kit (the bicycle chain)?? I am looking for a strong chain that can handle the torque of this kit without ripping apart![]()
If you are running a derailleur you're forced by the action of that method of shifting to use a chain that both allows a fair amount of side to side flex and torsional twisting. You also need to buy a chain meant for the number of cogs on your rear cassette. Go to your LBS and tell them you want a premium quality 7 speed or whatever chain. Shimano parts are usually good enough for me.
The big advantage of using a single run, single speed chain is that you can use a beefier chain that has thicker side plates and tighter tolerances for very little twisting or side flex.
