Lishui "Open Source Firmware" project / KingMeter 5S
Is the process described somewhere?
It't quite easy.
1. Install the STM32 Workbench and import the project like described in the wiki
2. Compile the code once by a click on the hammer icon.
3. Create a new debug configuration with the default settings (drop down menue next to the bug icon).
4. Start a debug session by clicking the bug icon.
5. Set breakpoints at interested parts and start the execution with the play button.
6. Pause the code with the pause button, to see which part of the code is processed at the moment
7. Check variable values in pause mode with "mouse over" or by expressions.
See the screenshot in this thread, it's from the CubeIDE, not from the STM32 Workbench, but both are Eclipse based, so they are very similar.
I tried flashing the firmware in Eclipse. The problem was the overcurrent protection tripping and going into an infinite loop.
C:
if(q31_i_q>(PH_CURRENT_MAX<<2)){
        CLEAR_BIT(TIM1->BDTR, TIM_BDTR_MOE);        //disable PWM if overcurrent detected
        while(1){}                        //stay here until hard reset
I looked at the Master branch. The current calculation and current protection algorithms there differ from the new-generation 12FET branch. Could you explain these differences in general terms?
Questions:
Are you currently using the new generation 12FET controllers?
I understand that the hardware differences between the new generation 12FET controllers aren't that significant or fundamental? The pins are slightly different, 64-128 KB of memory instead of 32 KB. My LSW12G-USAMK-F V1.03 1mOhm board also has 1mOhm phase shunts.
I'm wondering if it might be worth adapting the firmware from the Master branch for the new generation of 12FET controllers?
I would like to hear the author's detailed comments on these issues.
Thanks in advance.
And I kindly ask you to answer all the questions if possible, and not just the last one.:)
In the master this safety measure simply doesn't exist. I added it to the sensorless branch some day and when I added the sensorless feature to the NewGeneration branch, I copied it with the rest of the sensorless stuff.
Sure, my wife uses it on her NCM C7 :cool:
Obviously your controller needs quite long until the ADC inputs have stabilized, so you get wrong offset readings from time to time?
I thought so too, but now I see that with a delay greater than 500 milliseconds, the torque sensor offset is calculated correctly. Mine is around 900, which corresponds to about 1500 millivolts.
Does your wife's bike have a board with 1 milliOhm shunts?
Yes, I have not seen a Lishui controller with a different shunt value yet. But of course the shunt value is just one part, The backloop resistor on the opamp defines the calibration factor for the phase current in the same way. But this isn't related to your issue, I think.
You're probably right. But there may be other differences.
And still, please answer how much better the firmware from the master branch is debugged.
There are only very slight differences. The master has less possibilities for options like sensorless control, as it is really near at the memory limit of 26kB (32kB Flash, 4kB for the bootloader, 2kB for the virtual EEPROM). The only thing, you should think about is the watchdog, that is implemented in the master only. This would let your controller reboot automatically, if it hangs at startup (if you start the watchdog before the code stucks).
This bike continues to torment me in the same way. I set up data transfer in debug mode via the UART-HM10 to my phone and measured the actual voltage of the torque sensor output. It's the sensor that's glitching in the cold. While it's warm, 22-25 degrees Celsius, everything works fine. As it cools outside, it first gives the correct signal, then hovers at the offset level. Then, when turned on, it immediately gives a signal well above the offset and the motor spins without any pedal input. Then, it dies completely, with a signal at the offset level. Can you imagine the sensor's circuit diagram? Is there any point in messing with it? The stationary electronics are encased in plastic. The problem could be with the rotating part, as sometimes the sensor's state changes when I pedal backwards, or sometimes the issue occurs at a certain pedal position. But that's not certain. Your comments are welcome.
I also forgot to ask. Which inexpensive compatible screens would you recommend that are more informative than the EN-06? So they can show current and power.
You can use any display that supports the 5s protocol. Many manufacturers like Kingmeter or KeyDisplay offer various models.
Hi,
I got back to the sensorless_VESC for one and hopefully last time :)
I made some progress. the delays at CPU initialization resoved hanging at startup at specific voltage (my 48,6V startup E30 problem), E30 when touching PAS was PAS2_pin configured as IR without handling it - after setting it to normal input it's not hanging anymore, speed fluctuations were resolved by changing if(__HAL_TIM_GET_COUNTER(&htim2) < 12000) to if(uint32_SPEED_counter < 60000) in kingmeter_update(), there were some leftovers from TS config in the main loop, these had to be rewired for PAS that I have in my bike. now I need to put the battery together and test it on the road. I already see that motor engages too harsh, probably some more gentle ramps are required.
@stancecoke will you be able to advise on something? :) Walking assist works fine, and PAS support causes the motor to stutter, buzz, it looks like it's out of sync from the beginning. sometimes it buzzes, sometimes it starts backward. If I spin the wheel with walk assist up to some speed, then pas works ok. I am all the time talking about situation I have wheel up in the air. If I decrease target current with >>4 then it's not buzzing, but the torque is negligible. It looks like wrong parameters, I tried to play around with gamma, inductance, resistance to no avail. I did not touch spec angle and is seems to fall out of synchronisation even if it's already working. could you advise something here how to proceed further? it's eth1606 with geared shengyi rear wheel motor. I should have tossed into trash this controller long time ago :D
Edit: I also changed CAL_I from 38 to 16 as I have 6 fet controller and WATT reading seemed to be half of Power drawn from the battery.
Also I got only three pins in motor cable - you were mentioning 6 or 9 pin versions somewhere in other threads - might be my motor is some other version?
Yes the 1606 is a sensorless motor with an external speed sensor.
You should use the Sensorless VESC branch. Don't try to start with the wheel in the air, just ride as you would do with a normal bike. The motor starts in open loop, so you have to do the first initial push with your legs to let the motor start without load in the freewheel to find the right commutation.
The sensorless mode of EBiCS is not used very often so there is not very much experience with it.
The Sensorless VESC branch should work for the Fischer ETH 1606 out of the box, no changes are necessary.
Yes, I am using sensorless VESC version, I got a number of problems with this branch to struggle with, now when the controller is not ending up in hardfault I am struggling with this stuttering.
I recall that you mentioned somewhere the default settings of sensorless brach were for 1606 motor, but for some reason it does not work. When I am riding the bike it is basically constantly buzzing. If I am using walkassist I can hear motor is working, but the support is nearly none since current is divided by 256 (>> 8). Now I am wondering if motor is not the problem.
In config in comments there are values for Bionx - do you remember which generation? I think I have a 1st gen lying somewhere around, I can give it a shot.
With this commit/settings motor whistles like a mexican XD
I had to divide current by 255 instead of 5 because for sw900 gears are 0-255 and it goes well :)
I am still playing with some final things but it looks like we got this running.
@stancecoke kudos - you are the man! :)
Ok, here is my issue, hope somone give me "point" to look.
I use YCSV223 controler with STM32FEB made from WUXi company
factory controler not show watts , so I was thinking to read and unfortunatelly deleted chip :)
Anyway
so I did some basic configuration from Lishui software just to "wake up" this controler
Now ,it wake up, but shut down after 1-2 sec
Detection show is 5S so it wake up little bit, but not as should
Добрый день, достался мне контроллер lishui без дисплея , у меня есть дисплей s866, я нашел ваш проект и прошил в контроллер прошивку для видеокарты No2, теперь дисплей и контроллер общаются между собой, ошибки е10 нет. Я припаял к контакту sp,gnd,5v ручки газа. Подключил все через лбп, при нажатии ручки тока газа с 50мА подымается до 300мА, значит мотор пытается поехать, но он не едет.
Могли бы вы помочь мне настроить контроллер, чтобы он работал с мотором?26941.jpg26955.jpg27444.jpg
Please write in English.
Have you executed the autodetect routine once?
Please read the Wiki carefully!
Hello,
I didn't fully understand the instructions on GitHub. Some people from other forums tried to help me, but unfortunately their knowledge wasn't enough. That's why I'm asking for your help. Sorry to bother you.
So far, I have managed to compile the firmware for the No.2 protocol using Java and the Lishui Parameter Configurator. I then flashed it to the controller using an ST-Link V2.
After flashing, my S866 display no longer shows the E10 error. When I spin the motor by hand, the display even shows the speed, although the value is incorrect.
I also connected the throttle, but when I press it, the motor only twitches slightly from time to time instead of spinning normally.
The 8-magnet PAS sensor does not respond at all.
The motor is connected through the standard 9-pin hub motor connector.
Where should I start troubleshooting? What would you recommend checking first?
Thank you very much for your time and help.
Sorry, I didn't understand what "auto-detect" is or where I need to do it. Could you please explain what you mean by auto-detect and where I can find this option?
Thank you!
As said, please read the Wiki. The first steps to get the motor running and the meaning of the various parameters in the Java tool are explained there.
