Jeremy Harris
liveforphysics said:Please dont skew the rotor teeth....
It will only help with the torque ripple at the cost of efficiency, and mimimaly effect the noise.
Remember, the cogging isnt what causes the noise, its the alternating push-pull of the torque producing magnetic field flexing the rotor back and forth a whisker, much like a speaker.
A little acustic dampening material on the back of the rotor, or altering the rotor design would be better options IMHO.
Thank goodness for some more voices of sanity on this. I've done some work on trying to reduce the noise level from this motors big brother and the only thing that made an appreciable change to the motor noise was adding damping to the rotor disc. Changing controllers, even using an expensive sine controller, didn't make a massive difference to the motor noise, certainly not as much as damping the rotor.
It may be that the rear case acts as Bigmoose suggests, too, amplifying the noise somewhat.
Either way, I believe that it's an intrinsic property of a single-sided axial flux motor, so something that we've probably got to live with.
Jeremy
