Took Friday off from work so I had a full dose of ebiking today. Everything WAS holding up very very well, I'll get back to the "was" in a bit after I give some details of how well the Puma performs. This morning I made a bracket to mount a camcorder on the handlebars knowing I would be doing some range testing this evening with Joystix and Jondoh. I decided to try getting some video footage using the new bracket and thought a quick ride up the hills to a lake about 2.25mi away from my house would be neat. I started the camcorder and took off flying, might as well give the Puma the full treatment. It's pretty much 2.25 miles uphill, change in elevation from my house to the lake is 148ft to 590ft. When I got there I discovered the camcorder wasnt even on, coulda swore I started it. . . Sorry guys!
I then rode over to Joystix's house then had lunch with Ric and John, we discussed what our route will be for our range test later after John gets off of work. After John had left back to work, Ric and I did 2 Puma vs X5 dragraces. We started side by side with a 5-6mph rolling start then we both jump on the throttle at the same time, once with me on the Puma then another pass after switching bikes. Drum roll please..... With me on the Puma I cant say that Ric on the X5 is eating my dust only because after a block the X5 was too far behind. Ric out weighs me by 40lbs. With Ric on the Puma it was much closer of a race but the Puma is still the clear winner. We took videos of both with 2 different cameras, I'll try gettting around to editing the 2 for a multiview video of the races but I have more problems to deal with so I cant make any promises to when it will get posted.
So we all regathered at 6pm for the range testing ride. We plotted out a 18.5mi ride and planned to keep our pace to 20-22mph peddle asisting only from stops and any moderate incline. We all made the 18.5mi route then John and I decided to keep riding to get a true full range test. We were both at 21.5 miles when John's BMS's let him know it was time to quit. Mine felt like it still had more left in the tank, my setup bypasses the BMS's but I pressed the gauge button and it showed a blinking single bar. The pack voltage at this point was 50.4v, 3.6v per cell which is the perfect LVC for emolis.
Okay now for the bad news. John recharges his V28s and Ric comes up with an idea for John to hook up 4 of his V28s (2p2s) on his X5 and John to hop on and try joining the 40mph club. We strapped on a GPS to the bike and off he went. I drove while Ric camcorded him, he went WOT for a long stretch but never made it 40mph (did 39mph on GPS). Well after watching how close John got to the elusive 40 a devil popped up on my shoulder, you guys are going to hate me for this especially Knoxie after telling me not to give into temptation. I thought somebody has got to join the 40mph club tonight so why not me. I strapped on one of John's V28 packs to the GT and wired it in series with my pack, total voltage was 83.1v . Powered on the controller and gave it a little throttle with the tire off the ground, it spins and gets my heart pumping. I put on Ric's motorcycle helmet and jacket and coasted it down the driveway and onto the street. I gave it a tiny bit of throttle then ZAP, Ric and John were behind me as I stop and turned to them giving the cut-throat signal. Well we just found out the V28s are good for 2 in series through the BMS (2s) but theyre definitely not happy running 3 in series (3s). John's BMS in the V28 got toasted. John had to leave and I'm sure the ride home wasnt pleasant knowing I just fried one of his V28s. Well John theres some good news and some bad news. The good news is that I've already replaced the FETs on the BMS and ditched your original smelly battery case with a brand new one, for some reason I had 6 empty cases on hand :wink: Your battery is fully functional again 8) . Now the bad news
, when your BMS smoked it also took out my Crystalyte controller. After you left I went to connect up the battery on the GT then ZAP again, made a mess of the controller's and pack's black power pole connectors. Measured a dead short on the controller's (+) and (-) connectors. I peddled my way back home through 6 miles of hilly terrain, guess I deserved it. Cracked open the controller, looks like only 1 of the phases set of FETs are fried. Now I'm debating if I should just go ahead and replace all 12 FETs with 4310s for the lower ON resistance or just pick up 4 of the stock 4710s to fix the 1 bad phase. Guess I'm down and out again, but guys (Ric and John) you guys have to admit that this Puma is one kick a$$ little motor
