HighHopes
- Joined
- Mar 28, 2013
- Messages
- 930
thanks, just PM me with the link is fine. i'm always after more knowledge.
normally ferrite beads are to filter very high frequency noise.. but place between driver and mosfet in series.. my guess is that it is used to provide a slight damping on the edge rate of the gate drive current .. or .. somehow is there to change the resonant frequency to avoid oscillaitions between gates of a parallel mosfet topology.
i would say that the mosfet is designed to take very high rate of current (i.e. 15V pulse applied through a resistor to the mosfet gate pin) with no need to limit the di/dt by using an inductor. the rate is limited by the RC time constant of the gate resistor and mosfet internal gate capacitance. anyway, the mosfet is designed to take it, is tested & validated by the manufacdturer as such. maybe for RF application its different, but we're talking about a motor drive application.
for oscillations between gates .. like ONE gate resistor supplying current to 6 parallel mosfets for example.. yes it is possible that between the gate pins of reach parallel mosfet there could be an osciating voltage which would be very bad. this is why most power mosfets actually have 1ohm INTERNAL gate resistance built in just incase someone decides to put 15V direct to the pin with little to no external gate resistance. for me, i would not solve this problem by adding a ferrite bead. actually, if you look at zombiess' cadilack design you'll see 0805 size 0.5 Ohm resistors on each gate which is there to dampen (not avoid) the oscillations.
also you have to keep the gate pin & resistor away from the drain pin as you say because the drain pin has DC bus voltage on it while your gate resistor and ICs are only rated for a fraction of the voltage.. so keep far way! thankfully, in an effort to minimize loop area between driver IC and mosfet gate pin you will find that it works out in your favour to avoid close proximity of the drain pin. you tightly control the traces, their location, the componenets.. all in small area, no wild traces going willy/nilly where ever near drain pins.. no.
you could argue both. gate resistor must be close too the gate pin to minimize loop area & copper traces which have 10nH inductance per inch (or something like that). vias have a lot of inductance so you should try to avoid this. when you route the copper trace from driver IC to mosfet gate pin the return path (mosfet source pin back to driver) should be routed on a different layer directly underneath the supply trace .. not beside it.Should those be placed as close as possible to the gate pin on the MOSFET or is it more important to route the gate path away from the high current paths (source-drain)?
