Dui ni shuo de dui
j bjork said:How do you communicate with the controller now, by wire and computer?
Right now I just don't. I only have the bluetooth dongle, the controller either comees with a cable or a bluetooth dongle.
So basically right now I can't do anything, but at least I can ride the bike with the current settings.
j bjork said:I mean, I suppose you had to do a self learn and set it up like you want it after the update?
I did the self learning and programming before I updated the firmware, when it was still using the old firmware. I guess the parameters were still in memory somehow, it worked just the same after the update, only that the throttle lag was gone.
j bjork said:Do you know the name of your old and new firmware?
I have no information about the old firmware. No idea where to see its version or anything, I haven't seen it anywhere in the app, but maybe I missed something. I still have screenshots of the old version so if you know where to look just point it out and I'll see if I have the info.
The name of the file on the firmware they gave me was my controller's full model number. Which might or might not be a problem for a potential file sharing, I really don't know... I hope that the model number isn't hard coded in the firmware in a way that wouldnt' allow it to work on an unit that hasn't the exact same model number. There is no way for me to know that, so if I share the file please be aware that using it could be risky and potentially brick the controller...
High risk, high reward?
