The Super Commuter returns to plan A.
"FRICTION DRIVE". Well for a while anyway.
Development on my friction drive has continued quietly over the past 12 months and has now reached a point whereby some serious miles need to be clocked up on it to test its durability.
So a bit of an update.
Firstly, no more RC controller being used. I have come to the conclusion they are just too expensive and too fragile for a use in a commercial drive.
Gone to a modified low cost 6 FET but use the controller case as the main frame of the drive.
Now using 36v rather than 24v to allow the drive to operate with packs other than LiPo's.
No throttle at all anymore. Gone full pedelec. Few reasons for this. Firstly my local market and Europe must be pedelec. Secondly, the 6 FET controller has really smooth ramps up and down on the pedelec output that really suits the swing action of the drive. I personally really have warmed to pedelec on low powered bikes as it creates more of a seamless interface between the rider and the drive system. A standard 6 FET LED display is used. No point in reinventing the wheel when cheap off the shelf works perfectly well. The standard 3 levels of PAS assist provided by the stock LED display work well with the drive and give a nice range of assist from around 22 kph on the low setting to 45kph on high speed.
Designed a quick release system that indexes the drive back into the same position when re fitting it to bike. This was needed so the drive could be quickly removed and re fitted without the need to set the drive up every time. Drive can be removed and re fitted in about 20 seconds.
Drive mount is much more adjustable now and fits a much wider range of bikes. I would say good for 90% of bikes on the market
In relation to rideability, I am really pleased with how the friction drive is performing. Engagement is smooth and power delivery nice and progressive. Disengagement is a little on the slow side when you stop pedaling and is a bit disconcerting at first but its nothing for the brakes to overcome the bit of run on if needed. Noise wise, I think the 6FET is actually quieter than an RC controller.
Economy wise, the friction drive is at least as good as the SWXH setup. No problems getting 15 kms from the lightweight 3ah (2.5ah usable) 10s LiPo that I am currently using.
So that's about it at the moment. Although the concept is basically the same as original, it has gone through a complete redesign. Hopefully 2 years of work will finally pay off
I know the friction drive doesn't have the stealth qualities of the small hub but it sure ticks the boxes in relation to economy and keeping the bike as light as possible. It is so nice having the high quality rear wheel back in the bike complete with a White Industries hub and 9 speed XLT shifter and cluster. Bike rolls and shifts gears like my road bike now.
