gman1971
- Joined
- Oct 17, 2015
- Messages
- 997
KOMAN said:Gman:
5% km road with moderate slope of about 12% and less than 25 km an hour speed.
The kit is cyclon 1680w and weight 21 kg bike.
I happen to apage the engine and again at 5 minutes has run?
Greetings and thanks
12% is not moderate. Its pretty darn steep. I used to climb mountain ports in Spain on my bike when I was a teenager and a 12% grade is considered fairly steep. The cyclone 3000W is much bigger than the 1680W motor so sounds to me you're exceeding the motor capabilities; doesn't sound there is anything wrong with your motor.
When my bike had the GNG motor, there is an 11% grade here in Wisconsin that I ran at 15 mph uphill for 2 minutes, the controller was maxed out at 1200-1300 watts and the motor temp went from 50F above ambient to ~100F above ambient within 2 minutes. Sounds like you are having the same issue.
I see two obvious solutions:
1) slow down to 10 mph, (16 km/h)
2) get the Cyclone 3000W kit, which will take 1500 watts going uphill like nothing: I run the same hill that I ran with my GNG at 15 mph at 25 mph on the Cyclone and I yet have to get above 40F above ambient temperature.
G.
