Cool! What's your current setup, and what kinds of things have you done to lose weight?
I tried putting my 14s8p Luna 25r pack (13.30 lbs), in my backpack, and it felt really heavy. I'll try it to see if I can withstand it. I thought about getting their 14s4p 25r pack or their Mighty Mini 14s2p 30q pack. It has a 30 amp continuous 50 amp max BMS, so it should be fine for my type of trail riding. If the BMS shuts down, I can set an appropriate current limiter on my Cycle Analyst.
One thing I need to figure out is where to put the power connector, and what connector to use. I thought about using an XT-90S (anti-spark) with an XT-60 for less breakaway force for when I crash/fall. I'm going to get a dropper post, so putting the connector on the seat probably isn't a good idea. Maybe I could tie it to the top tube.
The aluminum versions of the chainrings aren't much more expensive than the steel versions. The 44T is just $20, and the 24T is $12. When I pick up the Cyclone's steel crankset, it feels so heavy. I have a $30 FSA ISIS crankset with a 44/32/22 on it, and it feels like a feather compared to the Cyclone. I'll definitely keep track of how much weight I lose and report back. I think the weight loss will be significant even for a non-weight weenie like me.
It seems like it would take a very, very long time to wear down 44 teeth. Large bicycle chainrings and cassette cogs are typically made of aluminum anyway, and I'm sure people get thousands of miles of use on those. Of course we're motor-powered here, so it will probably be different, but at least these parts aren't relatively expensive compared to cranksets that cost hundreds.
Another idea I may try is to use regular chainrings on a spider like this. I think it would look so much better too.
http://www.sickbikeparts.com/catalog/product_info.php?cPath=23&products_id=163
Here's a photo of a nice-looking crankset from this post.
https://endless-sphere.com/forums/viewtopic.php?f=28&t=69867&start=275#p1149602
The motor sheets feel very light. I plan to buy some 1/8" and 3/16" aluminum to make my own. I want to incorporate a chain drop preventer like the ones found on chain guides and bottom bracket-mounted bash guards. As you can see, it's just a small piece of aluminum that keeps the chain from landing on the bottom bracket shell (or in our case, the motor sheets). I'm also thinking about incorporating a bash guard as well to protect the large chainring.
This way, if the chain slips off the 24T, it won't get destroyed immediately by being jammed between the chainring and the motor sheet (yes, this happened to me). I just bought this metal hole saw to cut the holes. I can't believe how cheap it is. $14! Look at the costs of the other sizes.
https://smile.amazon.com/gp/product/B016U0QDNG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Föppel said:
Yeah, im on the same mission man!
A Bike with a lot of power is cool, but if it weights much, it feels like a tractor. For commuting thats not that much a disadvantage, but if you want your bike for offroad and fun-riding, thats a wohle other thing i.m.o.
i would start with the battery in Backpack, (if you dont do that already) to do that cost you nothing, and it will make a big difference in the Bike-handling.
Chainching small parts will not do much difference, mainly your wallet will get lighter, and like dingus said, they are often weaker...
one question, how thick are those Motorsheets of the Cyclone 3000W kit? they look like 4 or 5 mm, is that nearly correct?
