I like the Luna kit because it comes with black brackets. If you choose the ISIS crank arms, they are black as well. My brackets are raw aluminum, and I tried to paint them black, but the paint comes off once in a while. Other than that, they are fairly similar, with the exception of the $1000+ AFT kit which comes with upgrades that are mostly unnecessary in my opinion, certainly not worth the price. It has upgraded bearings in the planetary gearbox, but the regular Cyclone doesn't have any issue there. The crankset freewheel is a $20 part, at most $120 for the SBP version. They seal it with sealant, but all you need to do is drill 2 holes on the bottom to let the water out, or you can silicone it yourself. They provide upgraded brackets, but you can reinforce the bracket yourself with a few inexpensive parts from your local hardware store, or you can buy an upgraded bracket for ~$100. They provide a ball bearing idler pulley, but you can get one on eBay for less than $2 shipped. It's great that they have a "polished" version, but I think most DIYers are going to want to do it themselves. Gman has thousands of miles on his regular Cyclone. You could almost buy 3 Cyclones for the price of one AFT Cyclone. I really don't mean to knock it, but the price is just too much.
I think the AFT is pretty good value if you add up all the cost of the parts. you forget to mention it has the kelly FOC sine controller, acs freewheels and wipperman chain and i think proper instructions too etc etc its probably the best high power mid drive i have seen on here ?? and i'm still eagerly waiting for some reviews on it ....add those to the cost of any kit is a few hundred usd i would imagine so no wonder as it looks to be the best quality parts .
which part is unnecessary ? as they all seems to be different problems that have been addressed ? ceramic bearings ? they are a good idea in my opinion for people who want reliability and long life we use them in all of our motor upgrades at work, as apart from having less drag on the battery- who has enough battery ??? they would last heaps longer and more importantly be less susceptible to corrosion, if you read on here bearings are probably the number 1 failure mode of brush less motors and the stock cyclone is not even sealed ! so when water gets in their goes the bearings and maybe even the motor as it seizes up or shorts the halls..
