The vintage Banana Seat can be converted/adapted to Full Suspension Ebikes and give the rider a similar seat sliding freedom that motorized dirt bikes have. If you still just ride your ebike like you do a mountain bike that is pedaled this seat change likely is not in your current needs.
I began with a new "vintage" banana seat which have mounts near the front for clamping to the seat to the seat tube and side holes in the rear for mounting the back portion to the sissy bar. See the mounts:
For an adult male this built in metal seat frame/stiffener will not hold up to bumpy loadings when the mounting locations mentioned above are the attachment points and there are no additional stiffeners. The seat frame, even though it has a corrugated metal under shell, bent on me when I tried the first contrived suspension mechanism for this using only those points. After some thought I decided to cut and fit an ordinary slender bike seat under the spanning metal of the banana seat using only the OEM attachment points. The seat would stiffen the open span and prevent bucking of the under shell when giving it bumping loadings. See the trimmed down seat sides. The modern bike seat also adds cushioning so you have more than the minor amount of cushioning the vintage seat offers.
The trimmed down seat was fitted into the metal shell of the banana seat so as the front nose of the modern bike seat fitted into the 2 front clamping fins of the banana seat and then the rear of the modern seat was pushed back to where it just touched the traverse bolt that spanned the 2 banana seat's side holes. It was decided the a gear clamp could connect the rear of the seat to the transverse bolt. The material of the bottom the modern seat is a very hard plastic but a red hot butter knife can be used to burn a slit through the plactic seat frame. A gear clamp that adjusts to totally flat alignment can be passed thru the slit and around the traverse bolt to hold the rear of the banana seat to the modern bike seat. 2 gear clamps installed along this traverse bolt may be better than one.
And here is an end view of the gear clamp attachment:
Next the seat tube is clamped onto the rails of the modern seat:
Here we see the finished banana seat mounted on the Specialized Big Hit:
And 4 you stealth folks the seat comes in Black. If you mount the banana seat with these attachments the seat is quite easy to change.
Note:
On the Big Hit here designed the banana seat tip can dip only to the top of the battery pack mounted on the top tube. If you do not have such a material stop for the front downward motion of the seat you may have to add some form of a stop as there can be quite a bit of leverage from the front tip of the banana seat to the attaching rails and when loading it with all of your weight on the seat tip you may deform the modern bike seat's rails where they are attached to seat tube's clamps.
Edit 12/20/2016
The above banana seat was 18 inches long. There are longer banana seats and they may work closer to the likes of a real enduro seat as you can get more sliding length. The longer seats sometime >22 inches cannot be mounted as simply as the above method. The longest skinny profile modern seat I could fine was 11 inches long which likely will not have enough nose length to reach the standard fins of the remade 22" vintage banana seat when fastened in the rear as shown.
As I am new to such adaptions I was curios what a 22 inch banana seat was like. There are not very many options on eBay for this length but I did find one called the Lowrider which seems pretty good. As it is 4" longer than the 18" seat, the above mounting method does not entirely work. For the longer banana seat fasten the rear first as shown above. For the front, fortunately, the banana seats have included a piece of hardware that makes the adaption quite simple. To the included silver seat post clamp add a piece of 3/4 " copper tubing of sufficient length to go past the seat nose and extend over the attachment rails a few inches. Fasten the seat rail end of the tubing to the 2 seat rails with a gear clamps. See photo below.
Having a 22 inch long seat on a short mtn bike poses some body positioning dilemmas. 1) Where are you going to sit on the banana seat for normal riding? and What angle is most suitable for the terrain you ride? If you want the seat quite far forward you can even rotate the seat stem 1/2 turn -- for some stems this rotation will not allow seat attachment this way. I do not know much about these finishing adjustments yet.
But using the above simple ad hoc method of seat attachment without deliberation as to making a cutie bike seat attachment, here it is with an Allen bolt seat clamp as the toggle kind of clamps cannot be tighten easily enough to counter the extra nose leverage that makes for easy off angle turning of the banana seat.
