latecurtis
thank you.
I was just thinking about doing that with a small strand of copper wire like in the picture but I know I could never spread the solder like that with this soldering iron with the skinny tip.
For now though the terrible horrible butcher job I did will just have to hopefully work as I am almost out of bullet connectors.
I am about to charge Dan's old packs today. I will need to scrounge up enough connectors to make a parallel cable for combining two of the 5S packs into one,
I will simply have to disconnect it and hook it up to the other two for my return trips back home as i do not have enough bullets to make a parallel cable for all four packs to make it 20 AH.
Actually I may just run Dan's packs on the flat and keep that good 10.0 AH pack for going up hills as with my less than adequate gearing I will kill off the old packs quick going up hills. Thanks.
LC. out.
I am charging the second pack. Two more to go. They seem to be in good shape for their age so far.
I will be attempting to solder the parallel cables now.
I only have a little solder left. I watched the video but do not have that fancy soldering gun.
Ok I am taking a different approach this time. I plan on using locking pliers to stabilize the soldering iron so it don't move and my hands will be free to do the job.
Ok. the video proves that it is NOT my fault that I can't solder like the video that was posted. The soldering iron tip is too small to transfer enough heat from the bottom so that the solder melts on the top and flows evenly around the wires. although I do not believe I will ever be an expert at it I do believe that with the tool in the video (the soldering gun ) I would have been able to do a much better job than I just did.
https://www.youtube.com/watch?v=F_PfxDj-vww&feature=youtu.be
Frankly I am a little pissed off right now as it is 1 AM and Wall-Mart is closed and I am out of solder so only 1/2 of the parallel cable is finished. Also I have no shrink wrap but that is ok as I will demonstrate how to do it properly WITHOUT shrink wrap.
https://www.youtube.com/watch?v=DoCRz6USEmg&feature=youtu.be
No it does not look as pretty as shrink wrap but this 1/2 of a parallel cable shall work just as well as 1/2 of a parallel cable ordered from e bay. Tomorrow I guess I will make the other half of the parallel cable.
I am now going to install the controller and attempt to make my first waterproof installation.
Mission accomplished.
Good use of the bottom of a two liter soda bottle. I used the soldering iron to burn a hole thru the plastic for the screwdriver then after screwing the controller thru the side of the plastic basket 6 zip ties holds it secure and silicone plugs the hole.
Since the basket is over top of the motor a 30 gallon plastic bag over the top of the basket with a bungee cord wrapped around it makes the entire bike basically waterproof.
Notice that there is plenty of room to the right of that waterproof controller for a second waterproof controller when I get the rear motor installed. Once I get the other two packs charged and combined I will be able to bungee the cash box with Dan's old packs and once they are combined I will have 10 AH for the rear and 10 AH for the front motor. 1,033W total with 21 mph approx gearing.
Unfortunately though i guess I will have to hear about how shitty my gearing is until next month as it is the middle of the month and as usual I have no money to order more bullet connectors. I cant make a second set of parallel cables to combine the other two packs to run both motors at once. I can only run the front motor now.
The bike will be up and running as soon as I get more solder to finish the parallel cables. Also the controllers will all be plug and play so it will be as simple as a second front basket with the two 36V controllers mounted the same exact way but with a cash box containing 4 - 4 S packs. Two for each motor in series for 1,550 W total and 32 mph.
That wont happen for awhile though. Thanks for posting.
LC out.
LC. out.
LC out.
