new eZip motor
Status
Not open for further replies.
latecurtis said:
if charging 36V in series, the worst battery or some cells might be charging higher than 1C = 800% of maximum recommended.
Danger of extreme heat, swelling, Hydrogen/Oxygen gas production in weakest battery or cells ... maybe worse?
Exactly why I charge in parallel and I posted two pictures showing exactly how I do it.
You do know that a 12v battery is 6 cells in series, right?
latecurtis said:
The handle bars need to be extended, the seat raised up and the pedal chain, derailleur, gears and shifter put on. There is still much work left to do
At the very start of this thread, I endorsed you doing things out of the ordinary to either achieve an out of the ordinary result, or because you wanted a very budget build. From the last few pages though, it seems very much like a "buy cheap, buy twice" arrangement now. The first two, It sounds like you bought the wrong size bike. The rest of it... What was wrong with the original gear? I hope you are doing the work yourself, and not paying the same bike shop to do it.
$29 front and back installation doesn't sound too bad, but only because that's full commercial rates with rent and managers wages, and owner's profit margin thrown in. The first time I put on a complete new set of brakes and got them centred and with the right tension took me over a little 2 hours. I reckon I could do it in 20 minutes with a powered screwdriver now, and 30 minutes without. $29 is what, four hours of the minimum wage there?
On a completely unrelated note, I've converted my bike down to Justin's FOC controller. It was a PITA to tune, because there are so many different variables, but even my coarsest tune is miles ahead of my old controller. The new controller is about 1/8th the size, and the motor runs completely silent (drowned out by the noise of the tyre, which is already quiet. In plain air, you can just tell the difference between wheel spinning and the motor running. But only just).
SLA Inefficiency
Most SLA batteries are rated at a 20 hour discharge period.
Sadly, when in use at typical eBike discharge rates, 1/2 - 1 hour, actual battery output is a measly 50 - 60% of rated.
I finally found a graph that charts SLA inefficiency at various discharge rates.
(105Ah "20hr" SLA battery - modded decimal point to demonstrate 10.5Ah battery)
file.php
Relabeled graph for 10.5Ah battery and calculated for 4 x 10.5Ah = 48V 10.5Ah
(.05C) - 20hr 105Ah @ 12.5V = 131wh usable battery output x4 = 524wh
(.16C) - 5hr 86Ah @ 12.1V = 104wh usable battery output x4 = 416wh
(.58C) - 1hr 60.9Ah @ 11.9V = 73wh usable battery output x4 = 292wh
(1C) - .5hr 52.5Ah @ 11.5V = 60wh usable battery output x4 = 240wh
(3C) - .1hr 31.5Ah @11V = 35wh usable battery output x4 = 140wh
31.5Ah x 44V = 1386w x 80% maximum motor efficiency 1108w motor output for 6 minutes @ 30mph+ till new battery empty = 3 mile range @ 30mph.
4 minutes = 2 mile range @ 30mph recommended as much less damaging to battery! (but at that discharge rate will still deteriorate very quickly!)
As the Hub Motor Turns and the Lipo Fire Burns. 90mph!
10/4
Doug gave me the frame and wheels today. Pic 2. He was going to throw it out he said. For a really fast bike a rear drive rules. You don’t see many front drive motorcycles. Obviously that is the starter test motor. A much larger high horsepower motor could work there. It should be good for up to 90mph. If a motor happens to come my way in the future I will be ready.
I will need a three speed controller to get used to the power when I get a really sick motor. I think the 26" frame looks good on 20" wheels. This set up allows for a wide range of motor choices. I hate Road master. The sticker has to go and I may do a custom paint job.
The biggest drawback and problem with this of course is what to do about brakes. It is a big problem. Any chance for disk? Is there something that could be welded on to make disk work? The 26" frame and forks are larger than a 20". The 20" wheel gives natural gear reduction over a 26" wheel or larger.
Pic 1 shows the 56T sprocket. It is not only heavy but sticks out like a sore thumb. I will need to paint it black as well as the rim and spokes. Pic 3 and 4 shows the old 80 tooth originally on the Currie bolted to the 20" rim. Pic 5 shows the derailleur and I was thinking about taking the little wheel off and trying to use it for a motor sprocket.
Amp Flow, Golden, Astro, perhaps even an FX motor could fit in there! Another advantage of the larger frame is storage area for a custom LIPO rack and the controller in the large triangle. I am thinking about how I would build one out of wood.
Rough draft shows the brown triangles made from 3/4" plywood. They are the side panels everything else bolts to. The black things are nuts,bolts and washers connecting the wood on either side of the frame. The grey boxes are cash boxes full of Lipos in Lipo bags. The forth for the controller and LIPO terminals. If I can’t afford LIPO Battrack will allow me to mount up to a dozen 8 or 10Ah SLAs. Basically it is simply shelves custom built to hold the SLAs perfectly. The shelves bolt directly thru the main bolts to the side panels. The red and black dots are the terminals.
Properly done they will be held secure.
It will allow high voltage and plenty of room for the controller and hook up terminals. I will need a place to put my feet. This won’t be a pedal bike. It will be motor driven only. It may see speeds close to 90mph! The FX 75-5 is what I am hoping for in the future. I am not sure what controller and batteries I will need for that. I need to do further research.
Before all that takes place I just thought about the Currie. 20" wheels on the Currie? It already has storage capacity for up to six 12Ah Slas in the frame. How about the Currie pickup truck reborn? I like the sound of that for my next build. Please let me know if I have any brake options. It would be worth paying a welder to make it work.
10/5
The 11 tooth is not the correct size sprocket for the motor and again I wasted money! I asked multiple times for a link to the right sprocket to avoid this. It would have been better if someone simply said they don't make a motor sprocket that will fit on a Unite motor for a 410 or 415 chain. I have no idea what I am supposed to do now. I guess I will take the small wheel off the derailleur and drill it out and try to use that. Again like I said before my e bike building skills are only as good as the parts I have to work with. If I cant get the correct parts I cant build a good e bike. It is as simple as that.
I am out of money and may have excellent brakes (if they actually install them)on a piece of shit bike that will never work right with the new 56T sprocket as there is no motor sprocket for it. If they don't install the brakes I am scrapping the Diamond Back and moving on to my next build. I will be selling the Unite motor on E bay for $40. That is half of what I paid for it. I refuse to go back to #25 chain and will never order a motor that uses such cheap chain.
I wont know until tomorrow if the brakes got installed. The mechanic was not there and he may refuse to do the work because it is electric. I still don't have a 48V controller or the 1/2" by 3/16" chain. Also I am sick and tired of coming to the library to get online. I just got over being sick for a week and my ol lady is as sick as a dog. I went to the doctors last week and he refused to give me antibiotics. They don't give them out for anyone anymore as it is part of population control. They want older people to get sick and die. It is a fact.
I was born in 65. My spouse in 42. The first 25-30 years of my life I always got penicillin or amoxicillin the generic brand. I was never sick for more than two days taking it. Now they dont give it out anymore as they say it don't work. Its funny though how it worked for 30 years or more for me and her but now it don't. People here at the library are coughing and gagging and spreading around lethal germs. I am out. I have no idea when or if I will post again. I am not happy about the link I never got for the motor sprocket I really needed anyway. Peace out.
LC.
Ouch, looks like you ordered the 17mm Dual-D sprocket for the specialty gear reduction MY1020Z3 motor instead of the 10mm Dual-D sprocket for the MY1020 motor.
You chose the wrong sprocket!
Center sprocket, in link, is for the MY1020!
Read descriptions before ordering things!
No conspiracy here. It's called anti-biotic resistance. What happens is that when people are sick, they take anti-biotics. It kills 99% of the germs, but 1% remains. Quite often a healthy immune system will keep that 1% at bay, but when the person gets cold, stressed, immune compromised, they get sick again. This time though, when they take the same anti-biotic again, the germ has already been exposed to it, and is more tolerant of it. It might still work, but only kill 95% of it, and so it goes on, until after 30 years, it might only be 30% effective, and they give up on it and move on to different anti-biotics, many of which are still not as strong or as effective as the old ones used to be.
A bug called MRSA is resistant to almost every known anti-biotic known to man and is killing tens of thousands in hospitals every year.
This is why they are trying to avoid handing out anti-biotics in all but the most extreme cases.
Actually ...
The common cold and flu are caused by viruses.
Antibiotics are effective on bacteria not viruses!
If your cold turns into pneumonia ... then antibiotics will help.
If you felt better a couple days after taking Penicillin likely you had a 3 day cold, and would have felt better without it..
Antibiotics merely interrupt the reproductive cycle of bacteria, allowing your bodily defenses to catch up and wipe out the bacteria.
It is important to finish the 10-14 day "course" of antibiotics ...
or, the surviving-weakened bacteria can recover with a newfound resistance to antibiotics.
What you're describing there is called a bacteriostatic antibiotic. It stops the next generation forming, and you're right, it usually takes about 4-5 days before it really takes effect.
There is another type called bactericidal, which directly kills the bacteria. These work faster, but can have worse side effects. Been on them once... It was a special case, as it was 3 days before my wedding. Damn, did they work fast, but made me feel crap while I was on them, and I couldn't be more than 15 seconds from a toilet at any time.
On a phone got bike at shop in Eric's basement got 56 t. Perfect true wheel video 9 tooth perfect close to success got mongoose frame boo more d back 20 inch goose Will post as ......... We'd. If possible thanks l heard about that virus stuff. Was hoping not true but believe it now I guess. Need nanobiotics I guess
I did good deed thud is helping skalabala I think I hope I get that FX motor not telling how I may get it. I don't count chickens before they hatch but might end up with one
70 FX motory
KISS 101
Put the 26" back on the front and the biggest HD tire you can find on the back 20" wheel.
file.php
Gives you:
oem good front brakes;
rear deceleration from motor;
low seat;
semi chopper look
Bonus:
Add rack and mount motorcycle seat,
reverse handlebar stem
No updates for a week?
You still tracking well, LC?
Need a motor sprocket 410 or 415 chain 9 or 11 tooth. Getting brakes done will need 48v controller slas shot please post link for motor sprocketu
On phone library tommorow need to order motor sprocket.. The right one this time
As the Hub Motor Turns and the Lipo Fire Burns. 10/12 "U mad bro" Why I am mad bro!
It has been over a week since I picked the bike up at the shop. I called them before bringing it there. I told them it had a motor and was electric. They said as long as they did not have to deal with the electric parts they could do the brakes. It was about three miles there and the SLAs failed on the way. I plugged them in to charge and they told me it would be done five days later on a Tuesday.
When I got there they said they could not do it because it was a safety issue. I said so no brakes are better than brakes? How can that be? Then I found they unplugged my charger. I told them it was a special three stage charger only 1.8A. They unplugged it a couple hours after I plugged it in and never plugged it back in.
At that point I yelled call the police because someone is going to get hurt! A guy came out and I yelled at him saying you knew it was electric now I am three miles from home with dead batteries. He said we are not a battery charging station. The only thing that saved his face from being rearranged was he put the new brakes still in the bag in my basket.
I left with $44 worth of brakes for nothing. The $73 was an estimate for parts and labor. I never gave them a penny. F _ _ _ them! I am sick and tired of everyone being so prejudice of anyone with an electric bike. I ran the SLAs until they were destroyed as I had no pedal chain either. I got it to Eric’s pushing about half the way. Approximately 2.5 miles.
I have yet to get brakes hooked up. $63 later and I am still waiting. I am going tonight to see if someone can do it at Eric’s house. I got the calipers installed and the levers. The seat is raised up and it is ready for a pedal chain. I have a front basket for hauling things and am leaving the back basket for batteries. If I ever get brakes hooked up it will be ready for a 48V controller.
Also I don’t know when I can post this. I may go back to the Library Wednesday however if I see one person cough or sneeze I will turn around and walk out. I finally am about over with this virus. The ol lady suffered more with no antibiotics. I went to the heart doctor today. I told him I went to the gym for awhile. I did not like what he said. He told me not to bench press more than 100 pounds or I could blow out my heart valve.
I am not happy about that. I also got more BP medicine to take and they want more tests and possible surgery. I am scared to death of surgery. He also said I cannot work any construction job or do any heavy lifting or labor. He is willing to send social security whatever they need. That is five doctors saying I can’t work including the mental health guy. People half my age like Doug with nothing wrong but stupidity get SSI and if I get denied I may/should kill somebody!
At my hearing my lawyer had me discuss in detail two previous attempted homicides. One in 1998 and a second in 2013. Nobody died so I can’t be charged. I asked the lawyer before entering the courtroom. The vocational expert there never said a word. My lawyer said that is good as it means I am unemployable.
I never mentioned going to college and never did get a degree. So a GED and grade 9 education is all the judge has to go on. Also a reckless endangerment charge with a firearm. Nobody got hurt but I am classified as a violent felony and did two years in state prison. I will be extremely pissed off if I don’t get my disability. I am not building a fast bike first when or if I get a settlement. One of those neat little folding bikes with a small light motor is first.
I ran the Schwinn with the Lipos about 6 or 7 miles I think and slightly broke 3.7V per cell. I got a few 3.67 and 3.68V cells I think on one side. The front wheel with the Hub motor is slightly bent and wobbles a little from the accident I posted about earlier on. It was the first trip out for the Schwinn since then. I have been canceling doctors’ appointments for awhile and not wanting to ride plus I was sick. I had no choice but to go because he was going to stop my BP pill and I could die without them.
I hope I can get the brakes done. The box in the front basket is full of brake parts and tools. I replaced the steel brackets with wood. pic 5. I might paint the wood black. I will also be painting that huge 56T sprocket black. They could also have cut holes in it to make it lighter. With the heavy duty chain the front is heavy. What does it take to get a lightweight e bike?
I remember when this post first started DA said the 80 tooth sprocket for the first MY1020 motor for the Currie upgrade would be like a buzz saw. He was wrong. The 80 tooth for #25 chain was a lot smaller than this #415 - 56T. This thing looks like a buzz saw blade and is really heavy. When I order another sprocket for a spoke mount I want it made out of aluminum or something lighter.
Also the landlady was here for an annual inspection. She is taking half my security and raising the rent because of damage to the stairs and walls hauling 26" bikes up and down. I posted many pictures explaining why this 20" build was important to me. The B _ _ _ H blames all the damage to the outside stairs on my bikes and I take out the batteries,chainlock and anything else heavy and carry the bikes up the stairs outside. They don’t touch the stairs outside, only inside except for the 20" bike because I can pick it up high enough. Point said!
She wants me to paint the outside steps for nothing and did not want me to bring the Schwinn down stairs to go to my doctor today. I told her I might die if I don’t go. I really want to shoot the B _ _ _ _. I was always told not to hit women but told nothing about shooting them. She is lucky I don’t own a gun and can’t buy one because of my record.
I painted half the steps as it is my only exit. I will paint the other half later. That’s crazy why I have to explain to her. I pay $550 rent here and should be left alone! Me and the ol lady are both disabled and don’t need constant harassment. People like her are to blame for my mental problems and high BP. It is not my fault!!!
If that F _ _ _ _ _ g c _ _ t shut her mouth in the first place the Currie would still be running perfect. I actually did something right when I built that and ruined it when I took the motor off it because of all the bitching about keeping bikes in the hallway downstairs. I had two good running bikes in the Currie and the Schwinn with the front kit. I should have never bothered with a 20" bike in the first place. It has been nothing but a big pain in the ass and a huge waste of money.
However it is too late now. The 20" bike is still heavy but gets around the turn easily and the wheels don’t get caught up on the stairs. With a front basket and large backpack I could haul about the same amount of stuff as the Currie. I need a functional bike as small and light as possible. The 20" Diamond Back is 15lbs lighter than the Schwinn and about 20lbs lighter than the Currie with the same motor not counting SLAs because they are hauled upstairs separately.
Ok I am going for a test run with no brakes. Fortunately it is flat ground from here to Eric’s. I probably won’t go more than 15mph tops but will still get an idea how it is running and if it is capable of 25mph or not when or if I ever get working brakes on it.
I am back and inserting this. Brake prospects are looking good as I will need a new motor sprocket. I am leaving it there for awhile. More time to find someone capable of getting the brake job done. It still runs like shit! I think the dual motor set up ran better than this now! The 56T is new and the rim is straight. It has to be the motor sprocket. It only goes 10mph and makes a lot of noise. The shitty SLAs may have something to do with the lack of power. However the noise tells me the motor sprocket is the main problem.
10/1
I posted on my friends phone downtown but it is a pain in the ass. I rode the Magna. The LIPOs need a charge and have not had time to babysit them. The SLAs are shot and need to be scrapped. I am sick of e bikes. I may be sick of them but until I can afford a car I need transportation. Also I am not sick of riding them just building them. I never have the right parts and don’t know how to hook brakes up.
SLAs are shitty and heavy and LIPOs are a pain in the ass to charge and a fire hazard. However I can’t afford a car and still would rather ride an e bike when out late at night drinking than a car. If I am careful, ride the sidewalks when I can and pedal when I see a cop I have a much less chance of getting pulled over or hurting someone as there are very few people and traffic at that time of night. I don’t drink during the day.
There is hardly anyone here today at the library. Thanks for posting the motor sprocket. I saw it before spell checking this. However it is the time of the month where I am broke. I will have to wait until the 17th when I get $40 from social services. Hopefully someone can hook up the brake cables by then. I still need a 48V controller. I may have it going before the snow flies hopefully. With my luck there will be two feet of it. I may be able to return the wrong sprocket for the correct one. Looking into it now.
A new post hybrids has been created under large EV vehicles as that is the proper place to post but can still post here if you wish as far as I am concerned. Thanks
LC. out.
You really need to learn to chill. That actually IS a pretty bad example of bad customer service, but unfortunately, it's becoming all too common, and it's not hard to see how they would call your bluff and call the cops. With your record, I'm really not sure you need any more legal issues.
What I reckon is that they saw your bike, saw how much weight you were putting on it, and realised you weren't exactly going to be fighting in the Bantamweight category either, and thought about the speed of electric bikes - then decided that the legal liability of fitting the bikes was just a risk they didn't want to take. Giving you the brakes without a receipt is another guarantee that if they failed, you couldn't exactly go to the courts with the receipt and claim product failure.
I'm not surprised that you're sick of building eBikes. I mentioned about two weeks ago, that since I came back, your approach has changed from pushing the limits, to plain just doing things the hard way. I suspect with the amount of effort and money you've already put in though, you're not about to say "Let's take a step back and think about how to do this".
For what it's worth, I think you should just save up and buy a direct drive motor already laced into a 20" wheel, use the controller from the kit I sent you, and use the LiPos that was it Dan or DA gave you? It might seem like a big hit up front, but by the time you've experimented, got the right parts, paid off mates to do work for you and everything else, you're going to get nickled and dimed to death, and this will actually be cheaper. If you're going to be concerned that LiPo is fire risk, wait for your SSI and get a LiFePo4 battery. Unless you need really big amp draws, LiFePo4 is safer than lead acid, and only marginally more heavy/bulky than LiPo.
On the bright side, I feel like after 5-6 years of experimenting, I might have finally gotten the bike that's perfect for me. Or at least so close, I can taste it. Two weekends ago, I fitted Justin's PhaseRunner and my 60v lipos (68v hot off the charger). The motor is now silent and I go some pretty impressive speeds, but in doing so, I've damaged the clutch. I'm planning to fix that this weekend with some custom tougher springs, fill it with ATF, and crank the power up another 10-20% - not for more top speed, but to get a little more torque up hills. Once that is done, I'm going to try my hand at making a custom enclosure for everything out of acrylic sheeting, which will make the bike look totally stealth. I'm then going to invest in some quality Shimano running gear, to make pedaling more of a pleasure.
Anyway, back to you. Seriously, think about cutting your losses and getting a pre-built wheel. How's about one of these? http://www.ebay.com/itm/48V-Ebike-Electric-Bicycle-Conversion-Kit-Front-Hub-Motor-16-20-24-26-28-700C-NR-/361339092316?var=&hash=item54217cfd5c
I thought a clutch was only for gas motors.
Besides ordering the wrong motor sprocket because I did not read the item description properly I have about mastered e bike building except for installing brake cables. I can mount motors,change tires, I installed the spoke sprocket with a little help from a kid and I can install rear racks,baskets ect.
I really like the built in wheel kit and it would be great for one of those small fold up type bikes when or if I get my SSI. However if I get the brake cables hooked up, the pedal chain and the correct motor sprocket with a 48V controller I should be good. It is just going to take patience. Dan sent the Lipos. DA however has given me tons of advice and I have learned a lot from him.
The 26" frame with the 20" wheels towards the top of this page is where my interest lies. I am hoping that when I get money and move to a larger place like my own home I can have a garage with the proper tools including cutting and welding touches. My brother in law Mark is an expert welder with almost 20 years experience. He can teach me. I will be able to modify any 26" frame to install brakes with 20" wheels.
I may have my moments where I get extremity disenchanted but am not giving up on building e bikes for more than just a hobby. I have much to learn though. I may be interested in moving out of NY state to a place where e bikes are legal under state law. Also where I may be able to find an ES member/members who would like to work with me building e bikes. I would really like to open an e bike shop someday. Currently though I am very poor way below poverty level and waiting a decision on my SSI disability. Also I am going for tests next Wednesday and may be facing heart surgery and am scared to death. Until I get these issues resolved I cant make any rational decisions about my future in e bike building.
I tried using the 11 tooth double D 17mm sprocket with different washers and it has marks on it. I doubt they will take it back. I will need to order the correct one when funds allow. Also I hope to get the brake cables hooked up before then. Then when I get a 48V controller the Diamond Back will be finished. You are correct though Sunder in saying that that kit would be worth it. It would be perfect for one of those 20" folding bikes. I think I posted a picture of one somewhere on this page or the last for $300 without a motor. They go new $1200 with a motor and everything. I talked to a guy that has one but the motor was unhooked. He was pedaling it around.They are very cool as they fold up for traveling on a plane or a train. I am not sure if you can bring LIPOs on a train or plane but SLAs or LIFEPO4s would probably be ok.
I am not ready to cut my losses just yet. A $10 motor sprocket, brake cables installed and a $20 - 48V brushed controller will finalize this 6 month long 20" Diamond Back build. I may have spent way too much money on it but have learned a lot from my mistakes. Also before I forget I am extremely interested in that customization/fabrication stealth compartment you are constructing. Is there any chance of taking some pictures as the project progresses and when finished. Also a parts list would be helpful as I really wish to do similar work. I need to move on from cutting up milk crates to a more professional approach when it comes to battery,controller storage compartments. Thanks.
Sincerely LC. out.
It's not a clutch in the traditional sense, in that it connects the engine to the drive train. Rather, it's a roller clutch, that makes sure that when the wheel is moving faster than the motor, there's no drag from the motor.
This is a sprag clutch, but it works in a very similar fashion. Instead of using those weird shape sprags, it uses rollers like this:
Edit: Oh yeah, also happy to take photos of the current wiring/storage of batteries and controllers, and my finished product when I do it.
I want the bike so stealth that you need to have a look at it stopped or see me going 50km/h up hill without pedalling to realise it's electric.
the clutch is beyond my comprehension but hopefully someday I will understand it. Maybe if I see how it hooks up. Thanks for posting. Dan is working with a fellow ES member Skalabala trying to fix hall sensors in a huge brushless motor he is trying to get going. If you want to check that out I will edit this and post the link. Not sure what DA is doing but probably a little disenchanted with my last AS the . . . . . post. Hopefully he will post again soon. I have to get going. I am downtown and on foot. I must have left my bike chain lock outside when I carried my MAGNA pedal bike upstairs a couple of days ago as I could not find it and had to walk downtown to make my appointment at City Hall for my disability today. It is after 7pm and I need to start heading back.
The Magna is a decent pedal bike with great brakes and working gears. A perfect candidate for that little wheel motor you just posted. I should be at the Library tomorrow if you want to post. I should have the money by next week to get that motor sprocket and hopefully have the brakes fixed. If so I will have a video soon after. Thanks. LC. out.
https://endless-sphere.com/forums/viewtopic.php?f=30&t=72393
Hey LC,
Easiest way to ex[pan the one way clutch is just as the rear sprocket has one. It is free running when it is pushed past it's speed and locks up if the drive/pedal is faster than the wheel.
You need to be less worried about LiPos. Yes they can be dangerous but so can any battery. There was a story about 9v batteries and how they can start a fire. Any battery can explode or start a fire but they can also be very safe if handled properly.
I guess you never had a Lead acid battery blow up on you. I have, they can be very dangerous also. SLAs can burn too if they are over charged.
Remember, nothing is totally safe if you mess up.
Are you having trouble with the brake cables or mounting the calipers? the brake cable is probably the easiest too do. You might search here http://sheldonbrown.com/articles.html lots of helpful info there. Look at your magna and see how it is done.
I sure hope you hearing was a success.
Dan
As the Hub Motor Turns and the Lipo Fire Burns. Dirty little carbon footprints. / Brush vs brushless. FX 75-5 zero motors vs Astro.
Recently my ol lady got a letter from the state of MO. It is regarding unsettled property. She will be getting a check for an undetermined amount of money. We could not get an amount over the phone. A paper has to be notarized and sent in then within 90 days a check will be issued.
She has been unhappy for years now about me riding around and spending money on e bikes when we need a car. She has a point as e bikes are no good in rain and snow. Also I failed at building a tandem or sidecar to include her in my personal transportation.
After purchasing a car or truck if there is money left over after insurance I will be able to invest in further e bike projects. I am very against anything gas. My #1 complaint and am sure LiveForPhysics agrees is why should we have to inhale poison fumes every day especially in any city.
Even my ol lady agrees that people who live in the city age different from people in the country. A lot of city people have grey looks on their faces. Carbon monoxide and other poison gas spitting out of exhaust pipes are most definitely the cause. I am currently pleading my case for her to at least invest in a hybrid since we probably won’t be able to afford electric exclusively unless the check is very large.
My point is I know nothing about them. I know little about electric cars period as I am still learning about e bikes. All I know is that electric fork motors hooked up to standard transmissions to the reverse gear have been done. Also I know about 20 or more batteries are required and expensive controllers such as Curtis or Kelly are popular choices. I know Golden motors makes 10 and 20 kilowatt motors for really small vehicles around 1500 pounds.
As far as hybrids go I think it should be a law that all cars produced from now on be hybrid and running gas in any city or town should be illegal just like smoking cigarettes are in public places. The law should be in full effect within the next five years and within the next 10 years or by 2025 all gas and diesel motors should be converted to hydrogen or just running off electric motors exclusively.
Unfortunately with the influence of big oil tycoons on upper government we the common people have to be continuously subject to poison gasses in the air we breathe. I however for one do not wish to further contribute to this calamity. Any advice on what type of hybrid I should be looking for if in fact the check will even be big enough would be appreciated.
I doubt I will be able to afford anything new. A used hybrid is probably a realistic goal at this point. I was told that only the manufacturer would be able to repair a hybrid and that upgrades are close to or impossible. If a vehicle is capable of running even at a limited speed say 40mph or less on electricity without gas and if distance is limited to say 15 or 20 miles without gas I don’t see why the electric parts could not be replaced or upgraded.
The electric part of a hybrid must include an electric DC motor either brushed or brushless. Also a controller and throttle of some type and of course batteries. I know little about leaf batteries. I believe they are smaller, lighter and more efficient than LIPO or LIFEPO4. I imagine they are very expensive though. Any help on that subject would be greatly appreciated.
The only positive thing I can say about the gas end of the situation is if I need to travel a long distance to get to where a fellow ES member or members with the experience to upgrade the hybrid to the point where I can run it off of electric exclusively or at least several hundred miles so I would only need gas on really long road trips or cross country I guess then at least the gas will get me to that person or persons.
I will first have to get the hybrid then find that person or persons. People on this forum who are passionate on green energy and saving our environment and have the experience required to do such upgrades and or modifications are who I am referring to.
This forum is about helping each other out. I have gotten a lot of help here and have tried to help out fellow ES members like Skalabala. I don’t know how to get his motor going but asked several people like Thud, Dan and even Sunder today to check it out as I don’t have that level of knowledge yet.
I am not asking anyone to help ME (personally) on this subject because this is not about ME . It is much larger than that! I could just go and buy a big old pickup truck with a big stinky gas motor that leaks oil all over and go around scrapping metal and polluting our air and environment like most people would do.
What I am saying, whether anyone likes me or hates me please help out our environment! Helping me find and upgrade a hybrid is contributing to keeping the air we breathe and our environment clean. I may not live that long so if I were just thinking about myself why would I really care? I am 50 years old and I have a bad heart valve and could very well be six feet underground in 10 or 20 years if not sooner.
Future generations will suffer dramatically from greenhouse gasses, holes in the ozone and global warming as well as all the ill health effects of breathing in poison fumes their entire life and generations before them on this planet. If people don’t change the path we are on there will be little hope for the human race in the future!
pic1 shows the dual motor set up. I only got one motor. I gave the other away to someone who needed it for a scooter so they said. Photo suite shows how easily the dual motor set up could work. However my plans are the FX 75-5 motor. If it don’t happen two 3300W AmpFlow motors will be good for about 60mph. A third pic triple motors ( did that after a few beers) and possible fourth and fifth on the front are also possible but ridiculous compared to a good brushless motor.
Skalabala is 100% correct on the superiority of brushless motors. He may have picked the wrong one however. We shall see. I am wondering how two of those 20 kilowatt brushless Astro motors would compare to one brushless FX motor. Would it go faster and which setup would get to 80mph first? My guess is the FX motor. It says 70 foot pounds of torque. I don’t know what the Astro motors torque output is though.
I also heard that brushed motors such as the AmpFlow motor work better than brushless motors running off a single controller running two motor sprockets and one wheel sprocket. I actually did it earlier with the small brushed motors on this post and posted many pics and a few videos. Astro motors are brushless so a motor on the back and the other motor on the front wheel could still do the trick off a single controller. They just can’t share a single wheel sprocket. It is due to timing and I have learned this.
I don’t know the physics on DC electric motors though. I would guess they are more torque than gas but less horsepower as electric seems quicker and could soon rule 1/4 mile drag racing but it will be awhile before they can outrun gas on the flat. The 426 Hemi broke all land and speed records when it came out and exceeded 420mph on the sand flats about 40 years ago now. What is the fastest an electric vehicle has traveled today?
Pic2 shows how with touches and a welder the mounts for the brakes could easily be moved back to accommodate the 20" wheel. 20" forks on the front would enable brakes there also. I am not the only one who questions the importance of front brakes. My best friend Eric also unhooked them for years and years. He told me the story a few nights ago. They called him road rash in school.
He was going down a big hill and locked up the front brakes and flipped over the handlebars and scraped up his face real bad he said. I did it around the same age but was more scared than injured. We grew up about 30 miles apart and did not know each other until 2007. We both rode most of our lives without front brakes. However I do believe DA and you guys who are stating front brakes are 70 to 90% of stopping power compared to rear brakes. You scientifically stated and proved the point. I respect scientific evidence.
However as far as riding safely is concerned brakes take a distant back seat to common sense and being alert and aware of your environment. A good BMX guy for example would probably be able to ride anywhere with no brakes and crazy fast with back brakes alone. Front brakes would not matter much to a rider of that skill caliber.
It is more the rider than it is brakes that prevent accidents. I did not even apply brakes when I wrecked with the Schwinn three weeks or so ago. I did not see the bad spot in the road because I can’t see things in the dark! That is the worst injury I ever had. I don’t think I ever got hurt on a bike due to faulty or no brakes.
I may talk about going fast and may succeed in doing it but I assure you the faster I go the better aware of my surroundings especially in front of me will be and at a greater distance. Even though the Schwinn is capable of going about 25mph I rarely ever do it. I ride it on the sidewalk at about 5 mph a lot and maybe 10 on average on the street but sometimes get to 25mph but only for brief periods of time maybe 2 or 3 blocks. I can stay ahead of traffic long enough to cross the road and make a left turn when going downtown for example. Proper judgement supersedes stopping power.
It is almost winter and they are still catching up on pot holes around here. Please post anything you can on choosing a used hybrid / upgrades and modifications on hybrid vehicles. Also DA, I would really like to know how two 20 kilowatt Astro motors would compare to the FX motor.
I am thinking about an East coast vs west coast Death Bike race for the future maybe. LiveForPhysics has the west coast death bike. Maybe we should research and develop an East coast version. You are the scientist who does the cool graphs speed vs watts. I love them and have seen many. Please post one for the hell of it if you can.
On that note maybe I should not open another beer and eat some cookies, milk and trail mix and call it a night. That statement definitely requires a reboot for my tumor less brain (thank god). I will post this tomorrow. Post something about hybrids if you can. A new post under large EV general discussion named hybrids has been created if you wish to post there. Thanks.
Very Sincerely LC. out.
Cheapest and easiest just to pick up a 20" fork with brakes, or at least with brake mounts.
Hey again LC.
You need to get off the no need for front brakes. I guess you never had front brakes on your MoPar when you were younger, did you or not?
have you ever watched a CAR road race? Watch any road race or even a Bike race.
Years ago I helped a friend put a Ford front end straight axle on a Rambler. He only had rear brakes right after we did that. we went for a ride around town, he had to make a panic stop when a COP walked out and stopped traffic in front of us. He slid leftt and right slid for 50 ft and we were only doing maybe 30mph. The cop waited for him and told him to park it. he got a real ass chewing and was told to take it home and get it fixed or else. FRONT brakes do more than you would think, Bike, Motorcycle or cars. Only thing that I don't want to put font brakes on would be my Dragster, that one gets rear and a parachute.
As you've been told, front brakes are a must, if you ever need brakes.
I was telling an old racing buddy now biking friend that I never realized how much I use my frt brakes. He said you don't even think about it till you make a few panic stops.
Lc have you ever run over a squirrel or hit a deer while you were riding?
Font brakes have helped me on an occasion. If you ever get to that magic speed you are after I sure hope you have BRAKES, FRONT and REAR!!
I really don't know why I bother with this since you don't read it.
Dan
Status
