DAND214
Merry Christmas everyone.
Dan
Dan
LC wrote:If anyone has any answers to any of these questions please post. Thanks again.
LC. out.
You are a big guy grow some stones and get back to the GYM and get strong again. You don't need to press 300lbs but at least in good shape.
There are other advantages of chain driven, like variable gearing, but it doesn't seem like you're using those features anyway. Have you fallen victim to the sunk cost fallacy?
latecurtis said:There are other advantages of chain driven, like variable gearing, but it doesn't seem like you're using those features anyway. Have you fallen victim to the sunk cost fallacy?
Good point but dont know what sunk cost fallacy is.
latecurtis said:I am glad you brought that up as I really want to learn variable gearing and gear reduction. I mentioned that the Currie would be my first gear reduction project but if there is a way to do it with this 24" build and if there is a gearbox of some sort I could do then I should. I just dont have a clue and really need to research it.
latecurtis said:Midrive? If I can order a kit and install it and use it with an AmpFlow or even an RC Hobby King motor that would be cool. Cost and ease of installation are the main issues.
latecurtis said:you mean the red bike. I have not built the 24" bike yet. Also I am downloading a very interesting friction drive video and it is actually 15kbs. About half way done. I like the guys style and you will see why. Should have the link in a minute.
https://www.youtube.com/watch?v=I1krGMwaGLo
will be watching it in a couple minutes.
- read description!What is this?
- We would have to physically inspect all your circuits to determine the cause of failure. But a fuse is a minimal-essential basic protection that should never be gone without ... I personally tried to drill that fact into your head on a continual basis ... but, of course, you would not listen!I would like to know if a fuse would have prevented it from happening or would it still have burned out.
Guess you never "learned" in the first place ... ?I wish I could relearn what I learned 20 years ago.
Please use a little common sense ... or sober up.latecurtis said:http://www.electricscooterparts.com/speedcontrollers36volt.html#brushedmotor
CT-660B9 36V 1000W Electric Scooter Speed Controller
Designed for 36 Volt motors up to 1000 Watts. Maximum current 40 Amps. Under Voltage protection 31.5 Volts. Current limiting feature prevents controller and motor damage due to over-current conditions. Under voltage protection feature prevents over-discharge and extends battery life. Uses standard 3-wire variable speed hall-effect throttle. Fits many common electric scooter and bicycle models.
Item # SPD-CT660B9
Wiring Directions $54.95
Not sure if the cheap junk was hall effect ??? If it wont do a pot. A thumb is ok. Please let me know. Will need the Connectors. Got to check for a warrenty. Sick of getting ripped offSlow burn right? How many amps. 21? 750 / 36 = 20.83333333333333. or higher.
Will the radio shack have the solder stuff I need and connectors or do I need to order online?
