marcexec
Lebowski said:It would be easier for me to see what is going on if you post the hex (menu z option b) and remind me what version you have ?
To get the motor to start sensorless it is easiest when the motor is able to start with no mechanical load. The parameters affecting the start
are the wiggle rate and amplitude in the misc menu, some experimenting is necessary here. In a bike like yours it may be easy to
get the motor going by helping it a bit (bike on center stand, in gear, give a bit of gas and move rear wheel). Keep in mind that the motor
may want to go in reverse, then swap 2 out of 3 phase wires.
I'm back in business, drivers had to be replaced as well (one added 40mA in setup, the others prevented startup due to overcurrent).
It's version 2.30.
Code:
save the following HEX lines in a text file, including the '*' termination character
0x0747 0x00BA 0x0BB8 0x0027 0x000D 0x0005 0x7FBC 0x00D8
0x0000 0x0036 0x8000 0x010E 0x0087 0x0200 0x0400 0x0400
0x0400 0xAAAA 0xAAAA 0xAAAA 0x03E8 0x0248 0x000C 0x02DB
0x000B 0xFFCD 0x0280 0xFFFF 0xFFFF 0xFFFF 0xFFFF 0xFFFF
0xFFFF 0x00A4 0x02C8 0xFFFF 0xFFFF 0x0439 0x0036 0x01EB
0x01EB 0x0800 0x0258 0x0064 0xFFFF 0xFFFF 0xFFFF 0xFFFF
0x0000 0x4CCD 0x000C 0x0000 0x00F0 0xFFFF 0xB333 0xFFF4
0x0000 0xFF10 0x0000 0x07AE 0x0018 0x0000 0x01E0 0xFFFF
0xF852 0xFFE8 0x0000 0xFE20 0x0003 0x0000 0x0078 0x0000
0x0000 0xFFFD 0x0000 0xFF88 0x0000 0x0000 0x003C 0x0003
0x0000 0x0000 0x0000 0xFFC4 0xFFFD 0x0000 0x0000 0x0000
0x00F0 0x000C 0x0000 0x0000 0x0000 0xFF10 0xFFF4 0x0000
0x0000 0x0000 0x36AC 0x0A00 0x061E 0x05DC 0x00F5 0x0035
0x00E4 0x02C6 0x013F 0x0007 0x02BE 0x0042 0x0010 0x0E10
0x0000 0x03E8 0x00C8 0x5027 0x03B6 0x6000 0x00D8 0x013F
0xFF00 0xFF00 0xFF00 0xFF00 0xFF00 0xFF00 0xFF00 0xFF00
0xFFFF 0xC519 0x764B 0x5482 0x41B3 0x35C3 0x2D7A 0x276B
0x22C9 0x1F1E 0x1C28 0x19B5 0x17A6 0x15E6 0x1463 0x1312
0x11EB 0x10E4 0x0FFB 0x0F28 0x0E6B 0x0DC0 0x0D23 0x0C94
0x0C10 0x0B97 0x0B27 0x0ABF 0x0A5F 0x0A05 0x09B1 0x0962
Settings as above, 60V from LA test pack, tested the following:
Code:
Low side pulsing width 20
Wiggle range\Wiggle rate: 1 5 10 15 20 40 80Hz
10 X X X
20 X X X X X X X
30 X
40 X
60 X X X
Low side pulsing width 40
20 X X
40 X
Low side pulsing width 80
10 X X
20 X
40 X X
[youtube]Lssvkvrm6Ik[/youtube]
So, something broken, not enough voltage (I recall selecting components based on desired voltage) or keep messing with the settings?
