eyebyesickle
🚴♂️ Mega poster
so you guys are thinking its bad batch of gears / inconsistent / tolerance +/- issue?
and to be clear, terminology for gears not being my strong suit - I am talking about the blue gear, that is easy access, not the speed reduction gear or the big/main gear etc... same page here?
in which case swapping with another gear would test that theory - assuming the gear is not coming from said batch..
so we can go that route for sure, but brainstorming here - the only problem with that, is that theory does not line up with what we experienced with that specific batch, because it was the new high power version, and I even got some... you would think that if it was a bad batch of gears, it wouldn't be just 1.
I think it will be good to solve this one - I see its came up a few times for people here...
The only time I experienced it was when I was swapping the blue gear for the metal gear, back and forth... when I put the blue gear back in the 2nd time, I guess it wasn't right because it got loud. So, I thought maybe too much grease came off, I put a little more in, it slid in smooth, and then was quiet again...
So that is where I got the wishful thinking from, hah, but lets see if we can listen in on this, compare some gears, do what we gotta do and make sure all of the motors stay quiet!
