Nucular electronics - complete kit for ev!
WINNER! Tricky little bit of soldering ..all done
Vasili, if you hadn't of sent me on the trail of thought, I may never of spotted it.. just followed the tracks from the socket :bigthumb:
It was heavy crash, so obviously dislodged it.
Big thanks
Jon
I am still waiting on a pre-order for a micro. Can I decide to have it potted when my controller is ready or does that move me back to the end of the list?
Edit:
Oops. Just read back a few pages and remembered that all the micros are potted. Answered my own question.
Hi Vasiliy, does the bms measure the internal resistance of the battery cells and can it give the rated power that we are asking from the battery. Thank you.
We are shipping worldwide now by UPS, 60~80$ (depends on qty)
PITMIX i havent made that yet, we are still prototyping hardware
Edit:
Hi, what your pre-order number?
Anyone put a 24F on Electric Motion Trials bike? I am on the wait list. Got on in late May or early June.
VasiliSk said:
with some cooling yes,
What methods do you suggest for additional cooling of the controller? Just out of curiosity, has anyone ever employed Peltier effect devices on motor controller housings, or is the efficiency too low to be practical? I used some on processors and memory as an alternative to liquid cooling,but that was on a desktop,with abundant power.
New updates posted on wiki: http://wiki.nucular.tech/en:firmware
Controller update v0.7.18
Changelog since v0.7.12 :
Experimental logger added.
Fixed many charger glitches, however still have few.
Added soft start to charger and more safe phase detect.
Completely reworked field weakening, now should not have any hard braking after release.
Added minimum speed reference for speed PID.
Added RC PWM control on P1 port (throttle/brake).
Added more logger parameters.
Few important FOC control fixes, DC current should be calculated better under field weakening.
Fixed one weird ultra-rare bug in square mode.
LEVCAN operates on queues now, log time 2x faster when display updated.
Decreased DCi Ki default from 500 to 200.
Slightly decreased FW start point.
Added full debug info export.
Added logger mode selection and tuned logger start.
Removed first line from log for easy datazap upload.
Throttle / brake curves added (8 point configuration) with presets.
PAS extra scale added for additional modes.
Soft acceleration for cruise added, more shutdown triggers.
Cruise logic updated - phase current limited by selected mode, not throttle position.
Minimum cruise speed - limits cruise activation.
Cruise increment/decrement - control cruise speed with buttons ( port = CR+/CR-)
Cruise restore - recovery last saved cruise speed with button, activated only above min cruise speed. (port = CRr)
Power limit added to modes and battery configuration. 0 = power limit disabled.
Small menu fixes.
CAN inputs increased to 16.
Parameters export / import fixes.
12V shutdown fix.
Display update v0.60B
Fixed throttle drop.
Small menu fixes.
LEVCAN updated.
Button setup simplified, by default all set to CAN mode.
Added exFAT support (but display still can be updated only from FAT32).
Added charge screen.
Added fast statistics type selection.
Added wider event window.
Mph stats fixed.
Does the 24F controller has a 12V DC output to power lights, horns, and other stuff on a registered e-scooter?
Chambers i guess after NY, there is some new Production Adventures™ happening and need to wait a new batch.
bigbore New controllers will have 12V 3A dc-dc, about 2.5A you can use if you have display
So there isn’t going to be any new controllers sold for the rest of the year??
