On/Off switch with momentary switch antispark
TarMAC
Hi,
I have a setup with this parts:
https://endless-sphere.com/forums/viewtopic.php?f=35&t=56809
I wonder if i can use a simple on/off switch like this:
http://www.kjell.com/se/sortiment/e...gomkopplare/strombrytare-250v-6a-1-pol-p36092
to turn the power on and off. I will use it together with a momentary switch that connects to the negative pole through the resistor already soldered close to the ESC.
http://alienpowersystem.com/shop/e-board-kits/aps-120amp-3-2kw-single-motor-e-board-diy-kit/
Will this work or will the high currents make the on/off switch burn?
i dont think that switch will work, it says its only a 6Amp switch. your esc can pull 120Amps.
The anti-spark XT-90 is the simplest and easiest. I did a OCD version "how-to" here.
You can also buy a push-button power switch with anti-spark directly from DIYes. Or you can build your own from components (also in my sig) - using Vedder's anti-spark pcb.
HTH - GL!
