Alan B
It is a strange situation. At first look, connecting power electronics in parallel would seem to create a situation where a small timing error could cause disaster - a shoot through event where the power devices would simultaneously switch the motor terminal to both the high side and the low side. If this were to occur the FETs would be destroyed in short order.
But the particular way the phase switching occurs makes these timing errors (which are not going to be zero) into fairly benign events.
It is just not something that was studied carefully before.
I was ready to dismiss it as being a bad idea for exactly the same reasons, but when it worked I took a closer look and immediately understood why it worked.
It is good to learn something new every day.
Thanks for the experiment!
There are still risks doing this, and if either controller makes a mistake or misreads a hall it is likely to blow both controllers. The controllers may not share current the way you would like, depending. There are lots of details that affect this. But the thing that was expected - that the inevitable timing errors would immediately cause a shoot-through - that just turns out to not be the case. These small timing errors cause current to be run through 2 of the three coils in a compatible way. It is not the best way to get higher power, but it does look feasible. Controllers that were designed to be paralleled could do this even better.
