Mclewis1
🔋 Established
I'm looking at another ebike build that would offer more traction for occasional rougher trail conditions (mostly year round, but not too much deep snow use). I currently use a Surly Bridge Club with a 500w Shengyi hub motor and 27.5 x 2" tires/wheels. This has been a great upgrade over a 700c setup that was used for years for occasional commuting and grocery getting on urban streets and MUPs (plowed conditions but with lots of slush and ice).
The new bike would extend that type of riding (more stability in those winter conditions) as well as be a more comfortable ride on rural trails (but no serious MTB use). One option I've been looking into is just adding a new limited suspension fork to the Bridge Club but the 2 - 2.4" rear tire size limits on the BC are a concern in the winter.
What I don't want is a full on fatty (don't hate, just don't like them and want to keep the overall weight down) or a new mid drive (to much $$$ configured the way I like it). I'm considering staying with the same type of setup but with both a power and wheel width upgrade. Specifically using a 750w Bafang G62 hub motor with it's 170mm drop out requirement and 4" rear tire (keeping the front down to a 2-3" width). Yes this also means going down to a 26" wheel in the rear (need a wider rim), and that's fine.
One frame that appears to meet my requirements is the Surly Wednesday with the addition of a new suspension fork. Any other choices that I might look at? Some of the basic requirements are ~170mm dropouts, steel tubing or a very robust Alu setup with proven solid rear dropouts (but no thru axles), geometry that accommodates a suspension fork, and will fit a 6' 2" guy. It must also accommodate fenders, rear rack, and have room in the triangle for a downtube battery.
