Qulbix Raptor ebike + frame kit
Rix said:
QuestionMan said:
I like these clamping torque arms and that you will keep it 150mm standard as most people always need more room.
You see, that is why I made that post pushing (complaining :D ) about the dropouts because clamping type are so important, especially if you use regen. Even without regen I have read posts where non-clamping torque arms will put little play in the axle and eventually snap the axle. If it doesn't snap it, the axle nut will probably eventually come loose.
Now the only big question is will 150mm wide dropouts allow a cromotor 2 with disc brakes? This will be the last thing I would need to know before buying this frame. I think most people who buy this will probably go with a cromotor 2?
I think the Cro2 would fit just fine being the axle faces are 145mm. But the problem may arise with getting a rear brake to fit because there would be enought room to shim the rotor away from the hub shell for caliper clearance. Seems like thats what I heard and forget about using a Cog set (cluster).I can't remember who measured and broke down the dimensions of the Cro and mounting on the Bomber 162mm wide a while back and identified this issue. I could be way wrongwith the Cro option so please dont take what I just said as scripture. Another option would be the now available Crown which isn't as robust or a 54xx with the 150mm axle faces. I am really excited about the Torque Bikes Frame and cant wait to hear some reviews. Also the fact that Torque Bikes listened to some of the thread's commenters about the enclosed dropout mod says that they are sersious about being a player in the Ebike game which I applaud.
Rick
All, you need a 155mm minimum swing arm to fit the disc brake with a cromotor2. On the disc brake side you need to add another 10mm with washers to allow the clearance of the phase and hall wires, (145mm+10mm=155mm) I added 3mm more on the disc brake side and a thick 2mm washer on the freewheel side to allow clearance for the chain from the Phasor frame=160mm. Not enough clearance and then you risk the chance of damaging the wires from the disc brake screw heads. I also covered the cable with 2, 5mm cable ties to make sure that this didn't happen. I had to cut the washers (made them into c washers) if this makes sense. Poor design on the disc brake side on the Cromotor 2 to allow clearance for the cable exiting the frame. My measurement may not be %100 accurate but my swing arm on mp Phasors 160 and that accurate.
Torque bikes have informed me that you will be able to spread the swing arm to allow the 155mms required for a cromotor to fit and this is with a single freewheel. I tried a cluster on my Phasor with a 160 mm dropout and had to spread the frame 10mm. Decided to take it off as It was too tight and only had 5mms of room for the nut.
Actually a 160mm swing arm would be ideal on the raptor frame. Then I'd buy one.
Thanks for the break down Rod. Seems like the best avenue to cover everything would be a 135mm and a 165mm swingarm. The 135mm would cater to the geared hub crowds, the H35 and H40 as well. Then the 165mm would cater to the 54xx and Cromo crowd.
Rick
Rick
Yes I agree Rick, I and I'm sure that this will be easy to achieve. It's not enjoyable trying to stretch the swing arm and when you get a flat its even less enjoyable and some swearing is involved and a few beers after to get over it all.
Rodney64 said:
Rick
And lots of beers to help get over the beers that were used to get over the swearing. Truly a vicious cycle. :twisted: I think what Torque bikes wants to achieve is a universal width for all applications. But the problem is 150mm just isn't wide enough for the Cro and the 54XX, even though the 54XX can be ordered with 150mm Axles. I had one with 150mm axle, using the disk brake spacer it was just not enough for rotor clearance for the phase and sensor wires. Maybe a 160mm disk, but not a 203mm. But the 150mm will accommodate geared, H35 and H40 along with 9C and all the others out there with extra room to spare. Don't know about the Crown, but the performance numbers look good on Justin's Ebike CA simulator. Definitely not a durable at the 5403 but good.
EdwardNY said:
Uschi K. said:
Hi,
I just ordered a bicycle frame kit in silver/black with 150mm Dropouts. I paid via bank-transfer. Torque told me they will need approx. 3 weeks to ship it to Germany. So lets see. I will Keep you posted.
Regards
Lars :)
Could you let us know what motor, batteries, fork, crank you want to install on the raptor?
Basically I will (try to) use a CroMotor2 in 24" wheels, Lyen Freeway Controller, "homebuild" battery with 150 x Konion 2250V3 (25s6p), Marzocchi 888 and a Gatorbrake 8 piston as a brake (if I can fit this, let´s see). Hopefully this will become some fun. :)
Wow that is some setup you are building like a dirtbike. I hope you ordered the motorcycle seat if you plan to offroad this.
I think everyone who considers off roading should order this with both seats. From experience i can tell you that when you hit something hard and big your feet both get knocked right off the pedals. A motorcycle seat will ensure that you land back on the seat and not fall off the bike.
Uschi K. said:
EdwardNY said:
Uschi K. said:
Hi,
Regards
Lars :)
Hi Lars,
I dont recommend the gatorbrake !
You will not find any sparepart or brake pads in germany. The brake isnt good compared with actual brakes from hope avid or formula. Better go for one of them...
Where are you here in germany ?
Whoa guys, can i still join in on a group buy/20% discount??? I'm literally ready RIGHT NOW.
Well, I sent Degull an email...hopefully he hasn't placed an order yet or at least has the ability to add to it. However, if paypal isn't in play...then I might have to wait. But I'm just waiting to hear back from him.
Edit:
Nvm...Degull already placed his order. Hopefully we can get a discount if some members are ready to pull the trigger.
Maybe someone should confirm with torque bikes how the discount actually works. We do know that you have to order 10 frames to get the 20%, but is this for dealer pricing?
Would Torque bikes allow a group buy where torque bikes has to ship to 10 different people? Would payment have to come from one person or can 10 people send payment?
What I am saying is a group buy may not be practical and you may as well just order the bike. We need to confirm with Torque Bikes how exactly do you get a 20% discount. So if your interested in buying this bike right now then please E-mail torque bikes and ask about a group buy and how they would want it to work and post in this thread the details.
Believe me it's actually easier to get a wider frame than trying to getting it to fit.
Maybe u get it cheaper but when you get a flat how do you change it. Best to get a larger swing arm then use spacers
Rod, I can say the same, I learn from trial and error. I rarely make the same mistake twice. But yah, go wide on the swingarm and use spacers vs spreading swingarm and no spacers. With you on that all the way. BTW, the price listed is in Euro. The USD has taken a big shit against the Euro. Probably looking around 2k USD with shipping. Has anyone confirmed individual pricing and shipping to the US yet?
Rick
I just received a quote from them and they said 1024 + 80 shipping. Thats a little over 1400 with shipping. Still waiting on a response for group buy.
This is what the quote said about the cromo and the 150mm...
"The Raptor swing arm dropout is 150 mm. We have talked with the Cromotor and they say that the motor V2 has a dropout dimension of 155mm. The Raptor swing arm can be stretched 5mm.
Attached you will find a quotation for 1 Raptor Bicycle Frame Kit + shipping to US. At the moment only three colours are available - red, sliver and yellow.
The order is considered made, when bank transfer comes trough (we will send you a payment/order confirmation)."
If I'm not mistaken, it's already on their website.
EDIT: except for the shipping quote, I guess.
moonshine: so are you going to do the money transfer?
I guess the 150mm will work OK if you intend to use the single gear in the back. Personally I wouldn't use anything more then the single to make a clean install with less issues when I never would change gears anyway.
What worries me about the 150mm is if changing the rear tire is that much of a pain as Rodney said as my current bike is a huge pain with my torque arms, derailleur. However, after dealing with my current bike which is a big pain to remove the rear wheel I am sure that it will be much easier with this bike even if you had to stretch it a bit and deal with spacers. However, would be nice to be able to change tires more easily.
I guess if the 150mm is really that bad you could always maybe get the option to order a wider swingarm in the future. You can not get everything perfect. At least they put clamping dropouts on the bike, which would have been a deal breaker if they did not use them.
So, i'm gearing up to get the frame. I have the 150mm swingarm on my giant dh comp, but i had to stretch it another 5-10mm. I didn't have that much difficult with it. The most uncomfortable part is the fact that the dh comp's swingarm is ALUMINUM. These swingarms are steel, which makes me much more comfortable about "stretching" them.
150mm is the absolute minimum. For me, i had to stretch 5-10mm because of the dishing on my cro/large marge rim in order to get it centered in the swingarm.
My current set up has to be at LEAST 160mm wide since i'm running 24s4p. In the dh comp's frame, there's only one way to shimmy 16 packs into the triangle. I don't have any problems peddling...well except if its for more than 300 feet w/o power :lol:
1400 USD isn't bad for that frame. In fact its frickin awesome for what you're getting.
I'm looking to place an order, but will wait for their "group buy" response. If they're not gonna do it, then I'm most likely gonna pull the trigger (95%). I'll have to sell my dh comp frame....or just get outta the ebike hobby all together...stuff's gettin expensive these days....(that's the 5% left of my decision to buy the frame 8) )
$1400 is great for this frame, I ship things all of the time around the world. I shipped a couple of tires to a guys in Australia and it cost 259 bucks. Of course this was USPS as UPS was twice that price. So I was figuring around 4-500 for shipping the frame. Glad that's not the case.
Rick
I got a response back. The group buy discount is like someone mentioned in a previous post/also on the website. I guess they're currently out of blue, black, or green for the controller cover color (and I assume the seat mount). They only have red, yellow, or silver, but will customize the color for 20euros. See the email below. I'm also waiting for a reply about the customization to 160mm swingarm (that would seal the deal for me).
FROM TORQUEBIKES:
I've talked to our manager, and he says that we can custom colour your controller shield black or blue, but have to charge it (aprox. 20€). I'll let you know about the 160mm swing arm.
About the group buy - yes, we can send ebike kits to different locations and can charge separately each customer, but the discount depends on the size of the over-all order.
The group buy is considered a large order made by a non-dealer (also can not be a company). With every frame you get additional 2% off. That is why I suggest you set a time frame in which you try gathering as many orders as you can. If you succeed in reaching 10 or more frame orders we can give you a 20% discount. When you have a final list of customers, sign them in (you will find the document attached) and than we can prepare individual quotations.
Group buy discount - examples:
2 frames = 4%
4 frames = 8%
5 frames = 10%
8 frames = 16%
9 frames = 18%
10+ frames = 20% off.
The quote sheet asks for the following info:
I'll make this a google doc and people can fill it in as they wish...that is of course if everyone is ok with knowing other people's addresses. It's just a suggestion if there are a lot of people interested. I'm open to ideas as well.
edit...also waiting on a response about the status of their paypal account
For under $100 mass produced it is. You people are nuts to pay $1400 for it imo. That's twice as much as my complete bike battery and motor cost. I just don't get it.
Can you point to a mass-produced frame builder that fits or exceeds the Raptor specifications and costs less?
Yea...the problem for me is...i don't have the machinery/time to fabricate a frame like this. In addition, it's the quality behind a clean/organized frame + quality components that makes an ebike reliable at the level of performance I desire. Sure my dh comp is awesome b/c it rips and I put my heart and soul into it, but I'm getting tired of fixin little things and modifying stuff so that it'll fit the frame it wasn't meant for. SOOO...a frame like this is perfect.
1400 is not cheap, but by no means is it 10k like a bomber. Plus, nice mtb these days are at LEAST 1k with average DH bikes at 2k+.
Agreed, messing around with a bike frame is just tedious and trying to modify things to fit is just not fun after a while. I've been there and know exactly what you mean moonshine. I even saw in the stealth thread about people who bought a stealth and are happy that they do not have to fiddle with a bicycle frame anymore. It seems no matter how much you fiddle something is always coming loose. We won't even talk about the limited space in the triangle.
I guess it was a good leaning experience for us to build an ebike on a full suspension frame. It was fun while it lasted but when you can buy something like a raptor that is built specifically for an ebike I just lose interest in messing around with a bike frame.
I see your point about the frame costing $1400. It probably only costs less then $100 in parts and probably only like 10-20 hours to fully build. However, I still can not understand how bicycle frames cost over $1000 either. Those are also highly mass produced.
For me a raptor frame would be such a luxury, think about all the benefits you get below that you would not get or easily get with a bicycle frame.
Clamping steel drop outs (no messing with torque arms and will hold axle tight with regen) Anyone who built proper clamping torque arms knows how much of a luxury this is.
Fitting possibly 21+ 5000MAH LIpo packs in the center. 18s7p or 24s5p
Batteries and wires Fully enclosed in center (no worrying about batteries moving in a bag, and weight centered on bike) Just stuff batteries in center and fill with foam.
Steel frame that I assume is built to take hard hits from a heavy bike, especially a steel swingarm to carry the weight of a heavy hub motor. (no more worrying about an aluminum frame falling apart or breaking while you ride it)
Built for long travel suspension (much better than my 3 or 4" travel on my bike right now)
Able to fit 3" dirt bike tires or wide bicycle tires
Raptor has spot to mount controller under bike.
Option to have a motorcycle seat for a real off-road experience. (I looked into doing something on my bike frame but they sell nothing like this)
150mm swing arm (much more roomy then a standard 135mm bicycle frame)
