etard
I love the geometry of the Jr. Brute bike as built by Thud for me, and while we get some things sorted on that drive system, I couldn't just leave Grange Racer in the shed, so I'm building her into what I hope to be a formidable race bike: Racer X
Well, Thud stripped her bare before his Exodus back to Michigan, and left me here to pick up the pieces. LOL The bike is a perfect platform for a monster sprocket setup, but I have everything I need here for a proper Jackshaft drive, which I think will look cooler. So here is Racer X before It was stripped:
The Black One
Here is the mockup of the drivetrain I plan to run:
Ok, so here I have the 7KW Collosus, but I plan on using a 130 KV Turnigy 80-100. Drive system is 15mm GT2 belt drive 20T motor 60T jackshaft. I am using a hollow steel BMX shaft and one of Recumpence freewheel to shaft adapter. I will use screws to attach the 16T Dicta freewheel to the 60T pulley, allowing the motor to freewheel. I need to find a low profile bearing for the pulley, or I might incorporate a one-way bearing here for instant throttle response without the freewheel delay. I also plan on using a much shorter Jackshaft tube, this is just for visual detail. OK, on the other side we have a 14T #219 sprocket which I will probably weld to the shaft, going to this sprocket:
http://www.ebay.com/itm/180744415606?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_500wt_969
I believe this sprocket is a 46T #219 sprocket, but I'm not sure until I actually get it. There are a few motorcycles using #219H chains for their camshaft gears which I think is the same pitch as #219. It's not a big deal as I can just switch to a bit larger (64T) rear sprocket and bigger drive sprocket if not. What I am trying to do is get "inside" of the brake so that my rear sprocket is smaller than a 8" rotor allowing my to run the two off the disc brake flange, and keeping things relatively narrow. This way the Brake caliper will be above the 219 chain, otherwise, I'll just throw my Magura Hydro rim brakes on the rear. I also plan to make a proper battery box inside the front triangle. Don't get me wrong, these boxes are the best for switching out batteries, charging and don't get in the way. I just want to clean it up a tad.
I have a modded 12 FET Thud helped me build, and I'm gonna try putting sensors in the Turnigy and running at 72 volts. She should be a runner! I hope to get everything together before Jay64 gets back from Hawaii. Then we'll take all the bikes up to Grange and run some laps! Second best thing to actually running in the race.
The Black One
