scottclarke
Opening post for the benefit of those who asked for more pics in the ebikes gd forum.....
Apologies for the truly horrid chain tensioner - it was a chuck it together and see if it works item after spending many mental hours (2 days!) labouring over how I was going to do it! I'll work it some - give it some curves - it'll not look agricultural for long! The delrin wheel doesn't turn btw - I can turn it by hand as it wears though. It also serves as the guide that keeps the front sprocket where I want it - its an important part!
The sprocket is not held on by anything - it floats on the shaft to the point of lowest tension but is retained at that point by the tensioner/guide.
Quick specs for things without a label or that you can't see!
Outrunner brushless motor 200rpm/v 36V 90A though it'll use over 100 if asked - thats umm - 3.6KW
120A generic brushless esc 150a short term - its ok up to 45V I hear........... time will tell. It says 30 cells on it so should be ok.
Motorcycle throttle/grips.
Custom water bottle containing the linear pot, servo testing device, auxiliary battery, the esc and a fan.
Its currently geared 8:1 - you can work out the theoretical top speed yourselves. One thing I will say though - something I find REALLY cool - at top speed on 24V it doesn't slow down at all up a 10% hill I don't know about 36V because I had a fire during testing!
