on Nov.30th... The current setup has a 3220-7T driving a large #35 sprocket, which is attached to a 3-speed Sturmey-Archer hub. It has a CC HV110 controller and one of Richard's throttle boxes, both of which will get replaced by the Lyen's modified 12-FET. The pack used on this bike was a 12s3p Turnigy-based 44V/15Ah setup, which I will try initially to get a comparison baseline. Then, I'll try this with a couple other packs I have, a 16s2p 60V/11.6Ah pack and an 18s2p 66V/10Ah configuration.
What will be interesting is to see how the controller handles the loads and the rpm. With the 12s setup, the max rpm is fairly low, about 3800, but the current can be fairly high, with 80-85A peaks, if I push it. The 18s/66V configuration will push the max rpm up closer to 6000, which is right at the apparent limit, based on Lyen's tests. The peak current demands will be a lot less, though, maybe 55-60A. The 16s/60V setup should be right in the sweet spot, with a max rpm around 5000-5100 and max peak currents of 60-65A.
Anyway, should be an interesting set of tests. I've got a lot on my plate at the moment, but I'll try and get this going this week. First up I'll get some video (I got one of those small GoPro HD cameras the other day...) of the existing setup, with the 12s3p pack.
