Hello everyone, I learned a lot from seeing these technical discussions.
I want to realize sensorless position control of brushless motors: for example, when the motor stops, manually rotate the motor shaft several times, can the angle and direction of the motor shaft change be detected by HFI45 or other methods, and then the motor can be pulled back to its original position by control when needed?
