Fietsbel
This is my first post here, first have been reading a lot about a geared down rear wheel belt drive, got all parts for that, and than stumbled onto Adrian's friction drive concept, which is way more stealth and freewheels a lot better!... So took the motor I already had (50-65 turnigy) and the 190-200a HK SS controller, some pieces of scrap aluminum and bolted it in my MTB frame with a new smooth rear tire, with a nice flat surface in the middle, and it worked.
At first I made 2 supporting swing arms, with extra bearings, though.. due to the overconstraining by these extra bearings, they almost immediately ran warm/hot and died.. (took 600watt at that moment, while going 21kpu)
This single swingarm works like a charm, no extra bearings required.. keeping it simple is key here..
Battery is made up out of old, though matched, laptop battery cells, giving a 4s or 5s27p 47AH pack. (huge, though quite some range, and can deliver the req. amps)
Cruising speed at 12 amp~ 30kph (4s) and 38 kph with the 5s pack config, pulling 25 amp. Those 8km/u extra take quite some watts.(maybe it slips?)
This all still with the terrain front tire, better figures expected when the front road tire arrives.
At the moment I am running without friction sandpaper, just the can of the motor directly on the rear wheel. My best guess is that the tire profile allows this, as it is very nice and flat in the middle of the tire: vredestein dynamic city. I have some good cloth sanding belt, though I'm not sure of what glue will hold. (and that is available in the Netherlands)
Just wanted to share this with you, and thank Adrian for the wonderful concept I kinda stole .
Further I am looking for an a123 18650 6s10p pack... though what ebay seller can I trust? I ordered some cells at Cammy, and some cells at ohmygod, both performing quite well.. any other good sellers I am overlooking?
pictures
pictures
