steveo
Hey Everyone,
For all of you that have followed my previous threads, know that i'm a torque junkie, and i like not just a little but .. more power then i think i can handle. Since my first ebike buid, i've come along way in understanding every componet of the ebike. like, What it takes to make the proper battery pack, Build a strong robust controller, selecting the propery motor, and making sure it all works together perfectly.
My goal in this project:
I wanted to obtain the fastest accelerating ebike the forums has ever seen while being able to obtain a maxium speed of about 70-80 km/h, no i'm not trying to get any speed records out of this bike, DOC! LOL
motor
-Lets start with motor first, I went with a very low count motor (x5306) to accieve the ultimate efficency of any motor avaliable on the market, while achieving the absoloute best performace (without going into an x6 series motor)
-I also wanted a lowest current draw to allow componets like the motor winding, controller, to keep cool without having to drill holes in the side covers, I also wanted to have absoloutly the most minimal voltage sag possible.
controller
-I was very happy to be the first member on the forums to aquire a prototype 24 mosfet controller!. I've actually been waiting for this controller to be released for a very long time!. For those of you that recall my previous posts where i've tested higher voltage on to-220 mosfet controllers (12 mosfets) @ 133v, where i did have succes getting the controller to work, however when te controller ran to warm, the plasma fire occured destroying the controller. With the new 24 mosfet controllers i've aquire, I've know got alot more reliability going into these controllers, and am very confident that i should have great success running this controller on my new bike. The target is 144v @ about 50-100 amps depending on how the controller runs tempature wise, and depending on the acceleration ( just enough not to wheelie to hard off a launch )
battery pack
-I've decided to stay with a123 batteries for my new 44s 4p battery. These to me are still the best cells on the market even after 4 years. I've seen cells which have been overcharged, underdischarged, abused and a123 still come though, to a certain extent of course! I will assemble the batteries using sheets of .032" copper to solder the battery tabs to. This is identical to how doctorbass build is drag racing battery pack. Building your own battery pack does require alot of time when you are re-using cells. My entire pack will be matched by MAH & RESISTANCE to ensure the most capasity possible out of a 4p pack & lowest resistance possible and to ensure ultimate power output. I really can not see my batter pack seeing peaks over 100amps because at that current i'll most likley flip the bike over with the amount of torque. (I ran my x5306 for a short period of time on 88.8v of lipo ... and at only 50-60 amps could lift the front end easily). I will try to put majority of the batter pack weight on the front to prevent this from happening, and keeping the performance to the ground.
I will post photos as i go, I hope you enjoy watching my build progress.
Here is the link the the 24 mosfet thread:
http://endless-sphere.com/forums/viewtopic.php?f=2&t=14798
Photos of the 24 Mosfet controller build
video
http://www.youtube.com/watch?v=pjX1e3NiWvo
The New Bike frame with front & rear 203mm rotors
oh .. and this is my new ride .. full photo... i've kept thngs in the dark till i get the new controller & battery done ..
Photo update 2010/01/19
just some new photos of everything, I love my 1800 lumes 3.3v led lamp .. it is so awsome!
The 144 Monster Near completion...
The Torque arms, These babies have held up since day once, and i've already tested them on this bike frame with not problems, The bike frame itself has 1/4" steel drop outs. add another 1/4" with my steel torque arms!!
-steveo
motor
controller
battery pack
video
-steveo
