GrampaPete
- Joined
- Jun 10, 2022
- Messages
- 29
The TSDZ2 motors on a couple of our recumbents are connected to the battery via 2 sets of Anderson connectors. There is the wire from the motor, then a 36" extension, then the wire from the cradle.
You can be riding casually and everything shuts down. Turn the battery off and on and it comes to life. Ride a few blocks and the same thing happens. Check the connectors and they are tight. How should we go about debugging this issue? Could it be in the battery BMS? Does seem to be battery related because it only happens with a couple of batteries and it repeats on different bikes.
Thanks,
Peter
Thanks,
Peter
