99.9 is the percentage of the battery capacity.kaziq said:.... When pedaling the display shows the correct speed, but occasionally it goes to 00.0kmph, for a second, and then returns to normal speed. When riding uphill it is more frequent (sometimes 3-4 times every minute) and the display sometimes goes to 99.9 instead of 00.0.
When it shows 99.9 the motor stops assisting, and assists again when the display returns to the correct speed.
When it shows 00.0 and my speed is above 25kmph in street mode, the motor will pull for the time the 00.0 is shown. .....
Thank you, I know it shows battery percentage when turning the display on, and that it needs to be compensated. The problem is that it keeps showing 99.9 and 00.0 for a whole 3-hour ride every minute or two (more often when riding uphill). I would suspect showing battery percentage occasionally, but after one some kilometers it shouldn't be at 99.9 percent any more.Elinx said:99.9 is the percentage of the battery capacity 00.0 is the within the time the OSF need to compensate the odometer.
This because all data readings are measured as "speedlevel" on the display.
So if you measure 99.9 capacity fot 5 seconds, you need 20 seconds to compensate if you ride with a speed of 25km/h or even 50 seconds when driving only 10km/h. All this time the display shows 00.0km/h till the 5seconds is compensated.
The strange point is you say that the motorassist stops. This could be a bad speedsensor distance. This gives also 00.0km/h, but without assistence.
The 99.9 comes up when you switch on the display or the lights
You are right. This isn't normal behaviour. In the first place I should look at the speedsensor and bad connections.kaziq said:....The problem is that it keeps showing 99.9 and 00.0 for a whole 3-hour .... I would suspect showing battery percentage occasionally, but after one some kilometers it shouldn't be at 99.9 percent any more.
Mine is near the magnet too, because I thought it should be as near as possible. I will try to move it away then.kadleca said:I had similar problem with reading speed sensor. It was with the original firmware and the help was seting distance speedsensor. It was wery near the magnet.
I think it will be better to share your setup and we give feedback and comment it for strange choices and impossibilities.Suggy said:... emmebrusa software.
.... If anyone has the same setups could they send me any screenshots of there setups. ....
2300mm for 700C is possible but looks a bit high for me, have you measured the circumfence of the tire?Suggy said:I have 750w motor with 48v battery and i am using the vlcd6 display with a throttle and i have 700c wheels. I do not have any brake sensors or cut offs.
Can someone please check my settings
I add:Suggy said:I have 750w motor with 48v battery and i am using the vlcd6 display with a throttle and i have 700c wheels. I do not have any brake sensors or cut offs.
Can someone please check my settings. thank you
I forgotSuggy said:Thank you for reply
I see you have brake sensors this time? At the first place you said, you hadn'tSuggy said:... i have gone for these settings........
OK, I understand, never thought about that. In that case the distance will also be miles.Suggy said:...brake sensors.... is unticked the option for throttle is greyed out.
...value of wheel circumference so the vlcd6 will give me mph instead of kmh ....
All credits goes to mbrusa who invested a lot of time to get the OSF versions as they are now.Suggy said:Thank you ....
Nice to see another bluetooth-android interface for OSF version :thumb:feketehegyi said:.... for brave people who want to add more features themselves:".....
