Minatauro said:can someone remind me what exactly power boost is please? to know if i should have it enabled or disabled.
marcoq said:eyebyesickle said:Oooooh yeah.... great job on this. This is very much appreciated, a lot of people have been requesting this for a while... makes it so much easier to experience the upgraded motor functions. I have the 36v dialed in real good! Very happy with it. I am playing with the settings some for 48v/52v now.
Let me ask you this... what do you think about finding an alternate port for the temp sensor signal, and slightly modifying the code, so people can have the temp sensor function while still using the throttle. How much of a pain would that be?
Thanks again for your work on this!
Hello eyebyesickle
Thank you for the suggestion, in the future I can make the change, but for the moment I'm working to optimize some functions that can be controlled by the OEM display.
grecoa said:Hi Marcoq
Thank you for your brilliant work with the software!
Can you tell me do the Data Memory options and values stay the same with the new version software or do they change.
If they change do you have a document that shows the detail?
Also, I find with my system when I am riding If I turn assistance level to "Off" there is considerable resistance from the motor, is this correct?
Thank you
marcoq said:grecoa said:Hi Marcoq
Thank you
Hello grecoa.
Programming by java configurator, all DM data are always cleared, for data detail clik "help" button on java configurator.
grecoa said:marcoq said:grecoa said:Hi Marcoq
Thank you
Hello grecoa.
Thank you
I have found and read the Help document.
I have also managed to get java Configurator working (Path not set correctly )
The java configurator is very easy to use!
Any idea why I feel resistance from motor when assist level is set to "Off"? I am using VLCD5
Also, I have one VLCD5 system that sometimes does not turn on, just flashes the display and turns off, it can take 3 or 4 attempts to turn on. I see on your other forum that you plan to make a small delay when power on to allow code more time to load? Any idea when you may do this? I would be interested to try.
Thank you again!
marcoq said:grecoa said:marcoq said:grecoa said:Hi Marcoq
Thank you
Hello grecoa.
Thank you
Thank you again!
Hello grecoa.
I will soon release the new version of the firmware and java configurator! :wink:
ashrambo said:Marcoq, Would there be a possibility to redefine the buttons to be compatible with the XH18 ?.
I understand that the VLCD6 has 3 buttons (assist +, assist-, off / on) and the XH18 has 4 (assist +, assist-, off / on, information).
Using the assist-button with any combination is more complicated with the XH18 control ...
Enviado desde mi SM-G950 mediante Tapatalk
ashrambo said:I already solved the problem of the continuous power off with the XH18 display and this firmware, I had to activate the VLCD6 option always on.
No combination of keys works with the XH18 display ...
Another thing that I have changed has been to give more power to the walk assist mode, in the mountains and uphill it has no power, and the problem is that I use this mode when there is a lot of slope and a lot of stone and I need power ....
but although I put high values, I do not see much improvement ... any solution?
my settings
my settings
marcoq said:ashrambo said:I already solved the problem of the continuous power off with the XH18 display and this firmware, I had to activate the VLCD6 option always on.
my settings
For more walk assist power increase walk assist current!!! :wink:
elem said:Soo, the last configurator is stable ?
elem said:Grecoa, do you tried to reprogram with 00 all tab firstly ? ( before reprogramming ) .
on the other thread someone had this kinnd of problem and clearing all tab with 00 ( defaut tab in stvisual programmer at startup before reading existing tab ) had solved his problem .
elem said:Look what casinho is saying on the other thread, is wife human power is less than is own, as the motor is using torque ( human power ) and assist is a ration of this, it s normal that someone with less human power can t reach the same power than stronger ppl .
must put a stronger ratio asssist lvl on your wife controleur .
