Yes they work, but you will have to verify the new parameters added.Have I got this right, just unzip in new directory, point shortcut to the java exe and away we go, will my old setting files run version 6.
Elinx, thank you for your reply.The first thing I see is that you haven't calibrated the torquesensor.
In that case the default setting of it is almost ideal, what isn't mostly the case.
So calibrating can give a better result in this case.
"Set parameters at startup" enabled, means you can change different assist modes from display.
It is also possible to change this option from display (Assistlevel 0 - E02, =two pushes on light button).
You can find other display parameter settings inside the display manual page 3 (inside "Manuals" folder).
Also you can find how to calibrate the torquesensor on page 5.
It is also possible to perform an alternative calibration from display, without flashing again on page 6.
With that you can test if it gives the result you want.
Read carefully, because otherwise this calibration is temporary till switch off the display.
Found it: TSDZ2 mid drive with 860C, 850C or SW102 displays only -- Flexible OpenSource firmware (Casainho code only)I bought an SW102/2 to use with the TSDZ8 and the OSF. I opened it to flash the OSF for the SW102 (Initial SW102 firmware install). However, the SW102/2 looks completely different inside than the original SW102, there is no debug pad.
Does anyone know how I can get the OSF flashed onto it? Or is this no longer necessary to flash de OSF for the SW102/2 for setting all the parameters for the TSDZ8 OSF?
If there's no longer support, it's not a calibration issue.Elinx, thank you for your reply.
I'll try to do the torque sensor calibration, but I’m afraid that’s not the issue. I weigh 115 kg, and even when I push hard on the pedals on my son’s bike, there’s no assistance once we go over around 27 km/h.
Just out of curiosity. Will this work too with disabled "Set parameters at start up"...... "Set max speed from display"?
You should at least tell us what display you use.Hi all! I'm looking at getting my TSDZ2 system back up and running after it's collected dust for about 4 years. Last I played with it was using the original casainho OSF (I think it was the original). I've lost all my shortcuts from back then and I can barely remember what the reflashing process was, so I'm kind of like starting from scratch again.
Can anyone provide links to the most up to date flashing guide(s); basically the 'for dummies' links? I've had a bit of a search but the ecosystem seems rather more multifaceted than I remember from years ago, and I'd like to know that I'm looking at the most up to date information.
Thanks in advance.
Yeah my bad.You should at least tell us what display you use.
Yes, you can use the .ini files from version 2.2, but version 6.3 has new parameters. Check the manual to see if the default settings are OK for you.Final question I have both the v20.1C.2-update-2 and v20.1C.6-update-3 running fine on my laptop, thanks for your help, can I use the experimental and proven settings from 2-update-2 in 6-update-3 or will that "bugger the works up". Otherwise I can plug my spare monitor into the laptop and go dual screen so can have 2-update-2 and 6-update-3 across the two screens.
Many thanksYes, you can use the .ini files from version 2.2, but version 6.3 has new parameters. Check the manual to see if the default settings are OK for you.
To compare the two versions, you can open both configurators on the same PC at the same time.
If you have a TSDZ2 with an 860C display and have already tried the casainho firmware, there's a new version you can installYeah my bad.
860C
Very nice you have saved eco cycles instructions.If you have a TSDZ2 with an 860C display and have already tried the casainho firmware, there's a new version you can install
Release Firmware open source TSDZ2-v20.1C.5-update-1-860C · emmebrusa/TSDZ2-Smart-EBike-860C
There's the TSDZ2-vv20.1C.5-1-1-860C.hex file
for the motor, which can be flashed with "ST Visual Programmer".
The 860C_v20.1C.5-1-1-bootloader.bin file is for the 4-year-old 860C display, which can be flashed with "Apt Burn Tools".
There's also the manual, which you should read carefully.
If you've already done this, you should have the tools to do it.
To refresh your memory, here's a link for the motor.
TongSheng TSDZ2 what Firmware options are there?
The website for the display no longer exists; I had saved it as a PDF.
That is fantastic. Thank you very much for putting that together.If you have a TSDZ2 with an 860C display and have already tried the casainho firmware, there's a new version you can install
May be an idea, go back to page 113 when I was messing with my 48V TSDZ2B "but as the torque sensor seemed a bit limp or I am just a light weight, I increased by 20% the Power and Torque Assist Mode values to give me the same feel as on my other bike, did not want a this point in time to open the TSDZ2B up and mess with the torque sensor, know what load cell elements are like" I have put the screen shots there and no I did not a calibration, been fine since January.Elinx, thank you for your reply.
No, that's not the case.Hello everyone,
I still have two issues I can't seem to figure out. I've read the documentation several times and I really don’t know what I'm doing wrong. My display is the B02NU, and in the software I select EKD01 as the display type.
Problem 1:
I'm trying to switch between the advanced display settings (Data 1 to 6) using the light on/off toggle. I’ve correctly set the options in the firmware to display different data depending on the light status. However, I can’t seem to switch — it always shows Data 1 no matter what I do.
If I want to check things like motor power, cadence, or current, I have to reflash the firmware each time, changing the “Number of data displayed at light on” to the specific Data number. Is this really how it’s supposed to work?
From what I understand in the display manual, turning the lights on and off should cycle through Data 1 to Data 6, but in my case, it's stuck on Data 1.
Problem 2:
From the display, I can see that:
But when I pedal faster, the displayed motor power suddenly drops to around 100–150W. Shouldn't the motor keep pushing at 500W as long as I’m pedaling and under load? Max speed set from soft 40km/h. I did and set like you wrote.
- Max cadence with 34T-11T is around 80 RPM
- Max current is about 15-16A (I’ve set 15A in the firmware)
- At around 25–27 km/h, the motor assists nicely and shows around 500W (which I’ve also set in the firmware)
This feels like a significant loss of support after crossing that 25–27 km/h mark. Is this normal behavior? If so, please correct me — this is my first e-bike and I don’t have a reference point.
Thanks in advance for your help and patience!
I have to ask - is this 3 18v batteries wired in series or 2 52V batteries wired in parallel? Any issues with the configuration (with unequally charged batteries or batteries with unequal capacity, for example)?That is fantastic. Thank you very much for putting that together.
The DeWalt-o-cycle will rule the beaches once again!
When connecting batteries in parallel, it is essential that all batteries have the same voltage before connection. Differences in capacity do not matter.
When the batteries are connected in series, the voltage increases, but I would say you need matched batteries. When the batteries are connected in parallel, the capacity increases, I have used a double battery discharge module as I have a 36V 10 Ah main battery along with a 36V 7 Ah range extender battery, in this case both batteries are the same make.I have to ask - is this 3 18v batteries wired in series or 2 52V batteries wired in parallel? Any issues with the configuration (with unequally charged batteries or batteries with unequal capacity, for example)?
