I did actually mention in one email that I thought it would be better without threadsArtur said:without thread on a contact point you have more contact surface and less preasure on material of shock and shock support.
Ghost Rider said:I did actually mention in one email that I thought it would be better without threadsArtur said:without thread on a contact point you have more contact surface and less preasure on material of shock and shock support.
could you tell me the exact specification of those bolts so I can find them or are they custom made? Another question; I have taken the threaded bolts in and out quite a few times, could that have made the bolt holes bigger?
So, its okay to mount the bms on the side of the battery, good to know. There just isn't enough room in that frame for that battery. Thank god for the wide side covers.Artur said:you can mount it on a side. about wire colors i wrote yo email already. I recommend to use short cirquit switch to turn on off power to avoid a spark. glad that 3 layers of protecktion did a job!
Ghost Rider said:I still think it's weird that it's presumably okay that the bolts can move in the holes if they're not super tight.
On my previous bike(a full suspension XC bike), I couldn't move the shock bolts vertically even when they were completely loose.
Artur said:Ghost Rider said:I still think it's weird that it's presumably okay that the bolts can move in the holes if they're not super tight.
new bolts comes in a size that fit perfect.
how much would I have to pay for a new upper shock mount that is exactly 8? Plus threadless bolts?Artur said:Ghost Rider said:I still think it's weird that it's presumably okay that the bolts can move in the holes if they're not super tight.
Ghost Rider said:how much would I have to pay for a new upper shock mount that is exactly 8? Plus threadless bolts?Artur said:Ghost Rider said:I still think it's weird that it's presumably okay that the bolts can move in the holes if they're not super tight.
pucksterpete said:Does anyone have a source for the sidecover screws? I'm looking for screws with knobs on them to turn by hand.
It's M6.pucksterpete said:Thanks, I'm coming up with 5.8mm diameter, so is this a M5 or M6 screw?
Ghost Rider said:It's M6.pucksterpete said:Thanks, I'm coming up with 5.8mm diameter, so is this a M5 or M6 screw?
I got the new shock mount and the unthreaded bolts from Vector,
and this time the bolt hole was small enough, so there's no play anymore.
First ride with new shock mount:
The Vector moto seat is very comfortable, but I wish there was a taller version of it. (relative to the bottom bracket)
Don't want to use longer shock or flipping the mount because I want the slack head angle I have now.
Gonna try to find somthing to make a taller subframe for the seat.
Artur said:Very clean builtMaybe one of the lightest on the forum ) Glad the new bolts and mount is what you need, thank you for helping us :wink:
Also if you have ideas of what would you want to change on frame, feel free to post it here, I will definetly keep it in mind for our future frame designs.
What did you mean with "proper derailleur"?AccountMember said:What a difference in quality anyone on the fence about buying one don't be, I have used Qulbix too but the cost and the need for a proper derailleur was not popular
