maincraft said:
Hey!
What's settings must be here?
1) For maximum
TORQUE POWER from ZERO RPM (VOTOL EM-150SP)
2) For normal DEFAULT TORQUE?
Cheers.
This section is suppose to be for EV that is not direct drive, and has some gearlash or chain play that you want to take up slack on before sending max torque.
Starting torque is before slack is taken out of the drivetrain,
Combinative torque is after all slack is taken up in the drive train. (0-350)
Rate of rise is how fast torque can increase. (10-250)
Rate of decline is how fast the torque decreases. (10-200)
So if you ever saw a new driver learning to drive a manual transmission and saw it bucking like a Bronco, that is what this section is designed to tune out of a electric tricycle or anything with gears and axles that can wind up or have play.
But to your specific question, “what EXACTLY does each field do and what is the allowable range?”, that’s something many want to know, even on a hub motor ebike, so they can get the torque from zero up to where they want it without it being uncontrollable.
Oj my case i have an average height sidewalk curb that i need to climb to get to my parking spot. But it doesn’t want to climb it without a running start. I unchecked the “soft start” box and the behavior seems more predictable, but i only have a 500w motor.
I have played with the settings in this section a little but since my batteries are going bad and i have a new set on order, I’ll continue testing with new batteries so i know i have the volts and amp available.
Like you, I’m asking “why did you make a box if its always goung to be zero??!!!” Lol.
Ill play with it some and see if any adjustments helps get maximum torque at 0 rpm.
One thing to be careful of is allowed “locked rotor” current to go too high for too long, and if the motor cant spin to reach the next commutations point the 2 phases getting all the current will fry.
