HI Fijibrad
I find the 14ah gives plenty of range. It pointless to say howmuch range as things depend so much on speed, weight of rider, hills or flats or how you choose to use the throttle. Even using the throttle with pedal assist will hurt your range a bit so too many things to sift through to give any kind of meaningfull measurment on range for the pack - but I will say it has plenty of range for me. Long story short its a bike with a little under 700 wh and the bike weighs in at 50lbs with an XT 11 speed so keep the speed down and you can go a long way.
Had it out on the trails today again and the bike works really nice. Super smooth power, and a fun bike. The bike is not going to give the same get up and go like a 1500 watt HD1000 that is for sure, but you will mostl likely get more range per WH with this M600 torque sensing pedal assist because of the lower power levels, which also MAY mean less mechanical failures.
Getting used to the throttle as well, it seems like its got a bit more lag time from throttle to wheel than what I am used to with the HD1000. It is however very smooth using the Luna half twist it just means you hit the throttle a tiny bit earlier than normal for bursts of power when needed. And also - these are small bursts
. Going from 1500 watts on my Fat tire bike to around 800 watts on this bike is a different ride for sure....half the power is half the power - anyway you look at it but I knew this before I bought it.
So far I would say the bike has more than exceeded my expectations. Dealing with Dengfu however had its moments as described earlier in the thread.
Fijibrad, you say you are also thinking of the Frey AM 1000, I can not comment on that bike really as it has a differnt drive. The motor and frame look a little clunky to me but just my opinion. If you can afford the the bike I have here I would recommend it just not sure how the process will be to get it to your door with out the frustrations I had. My best guess is now that Bafang has supplied Dengfu with the batterys they will ship it all ready to go turn key, so this in itself will remove almost all of the problems I had with Dengfu. I look forward to hearing from others who will buy this bike from Dengfu, hopefully soon.
