ronncat
- Joined
- Nov 24, 2018
- Messages
- 36
So, I started wiring up the lights and hubmotor today. The hubmotor was pretty straightforward :wink: The lights, on the other hand were a bit of a challenge. As you recall I have the ground effects, LED headlights and LED tail/brake lights. They all operate off a 15 amp DC converter that will be powered off my 60V battery....
Did I mention that I don't have a 60V battery??? Was thinking of hooking up to one of my golf carts, but at 72V and 84V I was afraid I'd blow something up. Then I remembered the laboratory power supply I bought on ebay a few years back. Fiddled with it and finally figured out how to output 60V... Perfect
Then, things begin to go awry... Lots of wires everywhere... a couple questionable connections and the next thing you know, a blown relay on my optoisolator and an apparently shorted light switch. Well, apart comes the dashboard. Verified that the relay was a goner, and temporarily replaced it with a less than optimal spare. The switch fixed itself..I'll never figure out how
Well, back to the lighting. For my combination brake/tail light, I initially planned to run the 12V through a PWM dimmer for the taillight. This was to be routed through the NO portion of an automotive relay. The brake light would be the full 12V and would run directly to the tail/brake light. A secondary line from the brake was to run to the coil of the relay, so when the brake was triggered, the output from the taillight would be cut off........
I had already ordered everything I needed (Thanks Amazon Prime) and just decided to use the KISS rule.
A couple of diodes and a 270 ohm resister and I was done....So much for planning ahead
Just gotta wire in a SS relay so I can bring the 60V to the CA. And have to figure out how to hook up the CA to my Kelly controller. The end is in sight... Hopefully have it done before the summer!!!
