I found another set of issues with the conversion, dunno if either is fixable:
Links (at least in some posts and PMs, I haven't checked all the ones in threads) to individual posts like this one from a PM
This thing replaces Delta Tipper...er, Tripper v1.0, whcih was cannibalized to build it. https://endless-sphere.com/forums/viewtopic.php?f=2&t=22720 It's mostly Dogman's fault ;) ...er, inspiration, as he suggested it as a joint build for his trip out here this year. Tiny and Yogi discuss...
www.endless-sphere.com
and this one
endless-sphere.com
(from this post
The SB Cruiser : Amberwolf's 2WD Heavy Cargo Trike & Dog Carrier )
either did not (always) get converted, or aren't (always) being redirected (I don't know which is supposed to happen), because this only goes to the start of the thread, first post, not to that actual post (I don't know which post it was supposed to be or it's date, other than that it was about testing a QS205, around Jan2020; if I could search within the thread I could probably find it with just that info, quickly, but slogging thru the pages I found it is this one:
The SB Cruiser : Amberwolf's 2WD Heavy Cargo Trike & Dog Carrier ).
Next, probably not a conversion issue but a wierdness:
One example, in this page
Funny you shoudl say that... :/ Tonight, I had the problem again, while just sitting at the traffic light waiting, the lights went off, then came bakc on, stayed a few seconds, went off, falshed on and off a few times, then went out and stayed out. I tapped and whatnot on various areas I coudl...
if i hover over a membername on the left side, it pops up some of the member info, but does not have the bottom portion with follow, ignore, etc. It has this info (and the avatar/icon), for anyone in the thread:
Staff member
Administrator · From
Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion
Joined Aug 17, 2009
36,119 Solutions 1 Reaction score 51
john61ct
1 TW
Joined Dec 18, 2018
Last seen Feb 12, 2023 Messages
8,758 Reaction score 7
In other threads (which are also old, pre-conversion), like these
Hi All, I'm trying to open my 8000W (likely clone) QSmotor to replace a failed hall sensor. I got it halfway opened, but can't get the remaining outside panel off to expose the Hall Sensors. There is a BMX style freewheel sprocket attached to the threaded axle (going through the motor)...
endless-sphere.com
Did you ruin a line or two of that lovely grassland? ;) -
endless-sphere.com
it shows the expected info
igashosparks
Joined Jan 6, 2023
Last seen Today at 11:36 AM
25 Reaction score 0
Follow Ignore Start conversation
shortcircuit911
1 kW · 36 · From
Antioch, CA
Joined Feb 19, 2010
Last seen Mar 2, 2022
367 Reaction score 0
Follow Ignore
Start conversation
A separate issue is with the editor in WSIWYG mode (no issues yet in BB code mode). It does some wierd stuff. The catch is, I haven't been able to repeat any of it, despite quite a bit of trying. Most of it is things where it moves stuff around on screen that shouldn't be affected by typing in other places (like a carriage return that then moves stuff *above* it, as if a rubber band was cut). If I ever find a pattern or reproducible case, I'll post the repro steps....but until then, just a heads up in case others have seen this, and already do have repro steps.
