First off Thanks to everyone who has worked so hard on making this better than stock.
Now to the meat and potatoes of my post. I broke my bike, Warranty was not helpful. I'm hoping you guys can assist me.
What do I Have
I have an old bike with the TSDZ2 48v kit from auto-ebike.com. I have both a VLCD5 and VLCD6 (with throttle). I have a 52V battery. I Have an STLink v2.
the bike has 70km on the odometer
i have used many Firmware versions as the default 48v won't work with My battery.
What is wrong:
On 52v "stock" firmware I have no pedal assist and the throttle doesn't work. However if I hold the throttle and push the bike Backwards the motor engages and weekly assists.
On mbrusa's latest release I get an error 4 message when pedaling (torque Sensor Error i believe). The throttle does nothing.
What Happened:
at this time I was running Emmebrusa OSF fork for VLCD5 with a 52v battery set for 12A draw.
When riding it one day the assist abruptly stopped working and the Screen VLCD5 froze with 15km/h on the display and didn't update or respond to button presses.
I power cycled the battery and the screen became responsive again. showing current speed and changing modes etc. The Bike however had no assist through throttle or torque sensor.
after getting it back home I tried doing some troubleshooting With an adapter cable and vlcd6 screen and separate throttle i had on hand.
no change with a separate screen. still displayed speed and switched modes but no assist.
However this when i noticed that if i have the throttle Engaged and try to roll the bike backwards the motor engages and assisted. however as soon as i let go of the throttle and tried while in motion there was no assist. additionally this assist was very weak, very easy to hold the bike still with one foot lightly on the ground.
This led me to think that the blue gear was shredded and possibly causing issues with the assist being read. However when i disassembled the motor Everything is perfect as far as i can tell. all the gears are in great condition i dont see any discoloration on the Motor or Controller. I did notice that the blue green and yellow terminals were hard to separate from the motor leads.
I found some instructions online to test the controller (
https://ebikes.ca/documents/BlownMosfets.pdf).
I went through and tested as described and it looks like the Yellow phase mosfets (high and low) are damaged.
Green phase to Positive/Red = 129kΩ and increasing as the capacitor charged
Blue phase to Positive/Red = 128kΩ and increasing as the capacitor charged
Yellow phase to Positive/Red = 0Ω with no change
Green phase to Ground/Black = 119kΩ
Blue phase to Ground/Black = 119kΩ
Yellow phase to Ground/Black = 4mΩ
I got a New 48v 8 pin controller and installed it. however when I flash the 52V "stock" and Mbrusa firmware again I get the same behaviour as i had originally.
Will the throttle not work if the Torque Sensor is broken?
Could this be a Hall effect sensor in the motor not working? (can i check this somehow?)
what else can I check/do to troubleshoot the issue.
I have all the tools needed to pull this thing completely apart and have no worries about doing so.
thanks In advance
