You probably have a very sensitive torque sensor that senses even the slightest push.
Try to gradually increase "Pedal torque adc offset adjustment", maximum value 20.
ODO is managed by the display, the data sent by the controller is only the speed, in fact it is zero.
There is probably a filter (delay) in the display for viewing the green circle, and this increases the odo again. Nothing can be done.
If your display has a 6 pin Tonsheng connector, you will have a 6 pin to 8 pin adapter cable.
There are Y-cables for throttle, I don't know any with brake connector, 1T4 on the market have Bafang connectors.
I'm afraid it will have to be DIY.
