Wattster
Established
- Joined
- Oct 31, 2022
- Messages
- 71
How do you do that?You need to switch to calibration mode.
...to enter the calibration mode, you need to remove 0 from error count field, and with the key pressed " Shift", press twice " ~ ". You need to have english keyboard layout from windows settings.How do you do that?
Can you use another phone? Its never happens for BT recently.все еще ошибка доступа к bluet
I also NEED VOTOL EM50 Firmware.does anybody know where to get a newest votol firmware?
the video is already in privateYou don't need .bin file. self learning goes like in this video, but it works without that .bin file also.
self learning
You just need to do that reset once and then connect and save parameters. I don't know why this guy do it 3-times.
i can make new public video in future and post it here.the video is already in private![]()
how can i view the videoi can make new public video in future and post it here.
Have you looked at the problems posted about the Votol software? Are they ones you can live with vs the ones with the other controller(s) you've looked at?This controller should be released less than one month. I may order this controller as its competitor, The "far driver", seems to have bugs and glitches from the Feedback. Well, the far driver seems like a decent controller, It just seems that the software could be perfected more.
Note that new versions of anything are likely to be more buggy (hardware and software) than existing user-tested versions, so if you go that route, you may want to consider yourself the alpha tester (since the existing products too-often seem to be like beta versions).![]()
Vaporware would imply it doesn't exist at all, which is definitely not true.Starting to think this controller's vaporware.
How about an external speed limiting solution? There are a few ways to do it.Can anyone recommend an alternative to me that would achieve the speed limit feature I require?
Hello,how can i view the video
is there a possible way you can giveme permission to view the video please
Unfortunately having read about many people's problems over the years, and dealt with a few of them myself directly and via forum troubleshooting threads, I've become a bit soured on the abilities of the various companies' "software engineers" to deliver a truly useful, minimal-bug, and user-friendly product. Some are better than others, but depending on a specific usage or system, they all have one issue or another (most have several to many).I didn't realise all the programmable controllers were poorly implemented, it's the first one I've used.
That's certainly possible. Also, some systems only have certain parameters accessible via a Bluetooth type phone/device app, with others only accessible via a wired-connection computer-based setup program. I don't know off the top of my head which ones are like that, but there are posts about it here and there. :/You're right, not vaporware, I'm just concerned some of the features are vapor, or somehow inaccessible in the firmware versions made public.
A variation on external speed limiting would be to use two (differently configured) Votols in parallel and switch between them. Provides redundancy if one fails. And USD$50 for an EM-30S is a bargain.
Does the controller actually have a beeper inside it or on it's PCB? If not, then it isn't making the sound.Is anyone aware of the Votol EM 150 controller emitting a beep for any reason, while riding? Beep is a soft clear scooter horn sound. I'm assuming it comes from the controller?
Why you don't use 3-speed for different speed settings?A variation on external speed limiting would be to use two (differently configured) Votols in parallel and switch between them. Provides redundancy if one fails. And USD$50 for an EM-30S is a bargain.
Unfortunately the 3-speed feature restricts current, not voltage or RPM.
The speed limit/downhill feature(s) limits RPM. I just can’t figure out how to activate/deactivate either of them on the fly.
I don’t know which ports to assign or what type of signals to use. Neither will work on the default sport and 3-speed ports, which are triggered by grounding the 3v yellow-white, green-white, and black-white wires.
